Hey folks, in my hunt for a Ford pickup under $1000, I found quite a few 77-83 models with 302s and 351s. I was wondering if there were any particular years to avoid or years that had problems?
It all depends on what you want as far as engines and horsepower. This is just my opinion, but it you're looking for a 302, you might consider a 300 I-6 instead. They put out impressive torque and get much better mileage than the 302.
One other thing you might want to do if you're looking for an easy-to-maintain truck is get something from the era before electronics and if it is allowable in your area you might want to look for something without all the emissions junk on it.
The '80 models have been maligned for having a weak frame so you might want to keep that in mind as well.
My dream trucks are a 75 highboy with a 390 and a 81-86 4x4 with a 300.
Good luck in your search. I'm certain someone else will be able to give you more detailed information on the advantages and disadvantages of the various years.
Nate
1964 F-100 Custom Cab 292 V-8 3 spd
1964 F-100 292 V-8 3 spd
1990 F-150 5.8L
Check out http://clubs.yahoo.com/clubs/fordpickups61to66fseries
the 80-86's had squared off wheel openings. this can help to promote rust. i would also avoid first year or so of fuel injected. watch not to buy 203 transfer case(70's).
other than that, there are lots of old fords out there, so it says something.
The 300-6 had about 120 hp before EFI. After it was around 150. It has more torque than the 302( not sure actual numbers) Therefore can pull nearly anything you hook it to, but don't expect to do it very fast. Getting to 65 should not be a problem, though.
I wouldn't worry about what to buy for 1000 because you are not
going to have much to pick from. 2wd maybe, 4x4 for 1000 is
definitly going to be a fixer upper.
In 1980 the trucks with the week frames have holes punched out of the frame. They did this because the trucks were supposedly to heavy. When the frames all started snapping in half they decided that they better stop this. In 1986 they started putting in Electronic Fuel Injection into the F-series. I purchased a 1986 F150 4x4 no options except intermitend wipers. I paid $1000 canadian it and all it really need it was a hole lot of Body work. It has a 302 with a 4speed auto with Overdrive. You should be able to find a few deals like this around maybe not a dealership but a private sale. I would go for the 351W it has way more power then the 302 and burns about the same amount of gas. In the late 70 they had a 400 big block and these had tons of power. the stopped putting them in, in 1980 I believe. I hope this helps you out.
[font size="1" color="#FF0000"]LAST EDITED ON 02-Mar-01 AT 01:57 AM (EST)[/font][p]Hey, oldblue18, where are you getting your info?:"The 300-6 had about 120 hp before EFI. After it was around 150. It has more torque than the 302( not sure actual numbers)"'
It made close, but more? I thought it under cut the 302 by a few ft-lbs (five if my memory serves me)
I admit they may be CAPABLE of more torque (they kinda resemble a diesel in they way size is used) but they weren't made that way. think of how hard that would be for the salesman who wanted the extra cash from selling a v-8 off the showroom floor!
1989 F-150 : 5.0, shorty headers, Flowmaster cat-back, K&N filtercharger intake, March pulleys, "Multi-brand" performance ignition, soon to be Mass-Air...doesn't know she's not a Mustang
I bought a 80 f150 4x4 for a thou a few months back. It was a rustbomb with a good 351. I ended up purchasing a different truck because it turned into a daily driver and the 6-7mpg is expensive. I switched to a 93 with the 4.9 and It has plenty of power and has no problems going 75mph. (3.55 rear).
For the $1000 range I would go with a 78-79. My cousin has a few of these and they seem like alot tougher truck. (thicker sheetmetal, less rust).
http://members.tccoa.com/charlez/truckmain.jpg
