Offroad & 4x4
ford first 4x4
Old Mar 26, 2005 | 06:48 PM
gatorpsd's Avatar
gatorpsd
ford first 4x4
what year did ford put 4x4 on thier trucks?
Old Mar 26, 2005 | 07:07 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 27, 2005 | 01:01 AM
mustange70's Avatar
mustange70
Well techniquly it would be the ford jeep in world war 2 in 1940-41.
Old Mar 27, 2005 | 08:19 AM
gatorpsd's Avatar
gatorpsd
good point ,but what about f-series trucks
Old Mar 27, 2005 | 08:24 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
I'm pretty sure FACTORY 4x4 didn't show up until 1957.5 or so. Up until then (1953-54), truck manufacturers would send trucks to Marmon-Herrington or NEAPCO to have the trucks converted. It was then realized that they (the mfg'r.) could just build the 4x4 themselves in house and not pay someone else to do the conversion. So I think that the 1958 model year was about the first f-series with factory-installed 4x4.
This is likely wrong, but darn close.
Cody
Old Mar 27, 2005 | 04:00 PM
1962_Fords_rule's Avatar
1962_Fords_rule
Im pretty sure 1959 was the first year of the factory 4X4
Old Mar 27, 2005 | 04:07 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Yeah, a year or so before 1960....Ford themselves probably doesn't even know for sure.
Cody
Old Mar 27, 2005 | 04:31 PM
phoneman91's Avatar
phoneman91
!959 F100 was the first Ford factory 4x4.
Old Mar 27, 2005 | 04:50 PM
proeliator's Avatar
proeliator
1958.5 to be precise
But Mustang already came out with the correct answer to the first "ford 4x4".
Old Mar 27, 2005 | 08:42 PM
mstoned1's Avatar
mstoned1
not to thread jack or anything but jeep guys get really upset when you tell them that the last good jeep was made by ford.
hagen
Old Mar 27, 2005 | 10:09 PM
fishmanndotcom's Avatar
fishmanndotcom
....and?
i was under the impression that was the point ?!?!
-cutts-
Old Mar 27, 2005 | 11:52 PM
mustange70's Avatar
mustange70
Do i get a prize :
But yeah i also have a chance to get an old ford one ton (early 70's) in an auction over at the neighbors, and the guy grabbed the axles and t-case and stuff from a converted dodge (neapco conversion from what i've come to find out, big eaton front axle and matching dana 70 rear with 4.56's) and swapped it to the one ton, i should hopefully be able to pick the entire truck up for a hundred bucks or so as the truck is just trashed (also hopin to get a 77' 3/4 ton for parts dirt cheap as well).
Old Mar 28, 2005 | 12:36 AM
mako5972's Avatar
mako5972
I had a 1942 Ford Jeep when I was 14. I miss that thing. All the ingenious things that they did to it. Like use the flip up headlights to use them as runway landing lights. They had train wheels for them so it would allow them to run on train tracks, and a whole assortment of other things that I have since forgotten about. Wow, 28 years have gone bye since then. If I am off on something forgive me.
That flathead 4 would only do 60 mph in third gear in 2 high. Top speed in 4 high was 33 mph. First gear in 4 low was 3 mph. I don't remember much else.
