where i work in the summer the shop compressor is like 200 gallons. its huge. It has a huge 4cyl pump on it. It's like 40 or 50 years old. and it's awsome.
200 gallons...now that would be dreaming big. lol rfxj3, I guess I have been planning ahead a bit. I started looking at houses just to see how much I would need to be making to buy a descent size home but man, what happened....I couldn't find a house that was under 125 k....oh well, the main thing I really want is a descent stocked garage so I can continue this hobby that I've found. I've still got some time though. Thanks for all of the replies to this post guys.
Same one I got with my $250 gift card I got for christmas
Nice compressor, but those induction motors are NOISY bastaads!
-Larry
Originally Posted by WaterDog
I just went through this. I ended up getting a vertical 33gal/6hp craftsmen. It came with an impact wrench, ratchet, and chisel. It flows 6.4cfm at 90 psi so it will run most tools other than the drills and sanders. Paid $269 about a month ago. The fittings are cheap and the hose was useless so I got some better stuff. So far so good for this back yard hack.
Folks say to go with larger tanks but I've found that the same hp seems to produce more flow with a smaller tank- looked at CH, sears etc...could be a fluke. A smaller tank will rebound faster once you drain it down- though it will drain faster too. Also- hp ratings are crap on CH, sears etc- A 6hp rating is about a 2hp motor that puts out six with capacitor at start- they use max rating as advertising but list the operating hp in small print...sometimes. A lot of them are also oiless.
I bought a small roll-around compressor last fall from one of those Harbor Freight sidewalk sales. It only cost me $79.00. I have a large 220V cast iron compressor with a 100 gal tank in my shop already but wanted something light my wife could drag around and use for her crafts.
Anyway, that small compressor is so handy that I have not turned my big one on since I brought it home - it runs on 110, and even with 100 feet of cord. I roll it around the yard to air trailer tires, even inside the house to power my nail guns. It is a lot easier to move it than to run the heavy air lines to the big one - plus it uses a lot less power.
If I could have only one I would keep the big one, but the small cheapy compressor works good enough for most home use.
