Sponsored by: Real Truck
Diesel smell inside 01 SD???
Old Mar 26, 2005 | 04:43 PM
StraightlineInc's Avatar
StraightlineInc
Does anyone else have this problem? I just picked it up and the diesel smell wont go away.
Old Mar 26, 2005 | 05:34 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 27, 2005 | 01:29 AM
StraightlineInc
Thanks man!! I frequent a Ton of Car boards, this is my first truck board besides Jeep unlimiteds.
Old Mar 27, 2005 | 03:50 AM
tdister's Avatar
tdister
Does it smell of diesel fuel or diesel exhaust? If fuel then try wiping down int. sufaces (steering wheel, gear shifter, headlight switch,seats if vinyl, door panels) with listerine. If that doesn't work air it out (doors-breezy day) as often as you can (pretty obvious, but hey). If still no luck,air it out one day for a while and get someone with a good nose (females are usually better at this it seems) to try and pinpoint it. If it's a seat/carpet get rid of it-it's trash. Don't forget to check the seatbelt.
I went thru this recently after lending my car to a buddy. He was nice enough to fill it up-bare handed I assume (not nice enough to wash his hands before getting back in though) After the listerine and a night with the windows cracked it cleared up. Good luck.
Old Mar 27, 2005 | 08:37 AM
StraightlineInc
Ahh very good points, I just bought it on friday and after I filled up in smelled(didnt use gloves) DOH!!
Old Mar 27, 2005 | 08:55 AM
MobeyDick's Avatar
MobeyDick
You need to check the Fuel filter for leaks not a normal problem but someone may have changed the filter and left the old seal on or not put the new one on, and the Fuel bowl drain, make sure it"s not slightly open.
Never use gloves or mitts to fuel been driving Diesels for 9 years and never had a Fuel smell in truck. But you can get it on you shoes around truck stops so watch out for that.
The only time I've ever smelled fuel in the cab was a bad fuel filter problem!! Had someome else install the thing abd they left the old seal in and installed the new one. Leaked all over heck and gone!! After I fixed it the smell went away after a few days!!
Old Mar 27, 2005 | 09:18 AM
captchas's Avatar
captchas
Guest
gloves
get a box of latex gloves if you don't have a problem wearing them helps a lot. best of luck with your ride
Old Mar 29, 2005 | 12:43 AM
Steve_250's Avatar
Steve_250
Easy mistake.....
Watch where you step. Often times near diesel pumps there will be spillage on the ground. It doesn't evaporate like gasoline does. I stepped in some when I got out to fuel. Got back in, rolled the windows down and everything. Then I finally realized, oh geez! Dummy, you stepped in it!!
