there are three wires from the altenator. two go to the starter selenoid switch,where does the other one go?I found it laying on the engine burnt and i dont know what it connects to.
well, hmm, the two to the solenoid is for the charging gage in the cab, the other, id have to look at my truck to tell you, its dark and i don't have a drop light so its a no go there, i would guess its some type of power return? i've never heard of this,but alas i don't have the repair manual so i'm guessing here without eyeballing the wires first
Large black/red-stripe goes to soleniod/battery connection
Orange/light blue-stripe goes to "F" on regulator
If you have an "alt" light, white/black-stripe goes to "S" on regulator and also can go to the electric choke/carb (optional)
If you have ammeter white/black-stripe goes to choke only
