Help! What Could be Wrong
Old Mar 26, 2005 | 11:00 AM
Monica's Avatar
Monica
My beautiful truck had to get towed yesterday
I started her up and she was idiling really quietly, I thought it sounded strange. Then I put her into gear and she started smoking hard. When I tried to drive no power and lots of black smoke. Got her back in the yard and called a tow truck When we started it to straigthen the wheels for the tow, she just smoked lots then stalled when put in gear
Does it sound like I'm in big trouble????? I just had it serviced with and oil change and inspection less than 100 miles ago.
Old Mar 26, 2005 | 11:21 AM
mustanggt5's Avatar
mustanggt5
Smile
Sounds like the EGR valve if so simple fix, happened to me at 5 ,000 miles.
Old Mar 26, 2005 | 02:20 PM
SBV45's Avatar
SBV45
If it happens in the future, shut off ignition, disconnect the EGR, start it back up and see if the symptoms persist. If the EGR is stuck open, that won't help.
Old Mar 28, 2005 | 06:09 PM
Monica's Avatar
Monica
Yup as usual you guys were right. They were a little floored at the dealership when I told them that I had diagnosed the problem and what they needed to fix
They also told me that if if happened again and I disconnected it, it would run long enough for me to get it to the dealership and that's about it.
My question is after reading up on it, is it better off left disconnected all the time?
Old Mar 28, 2005 | 07:31 PM
kw5413's Avatar
kw5413
Well Monica..Mine fell off about 12,000 miles ago.
Glad the site was able to help out BTW.
Old Mar 28, 2005 | 10:19 PM
Monica's Avatar
Monica
He he he, so when they fall off there is nothing to worry about then Better for me than a dead broken truck on a holiday
Old Mar 28, 2005 | 10:52 PM
olfordsnstone's Avatar
olfordsnstone
Nice thing is, when they fall off while the egr is closed. Well, it stays closed. If you wait until it is stuck open. Well.......
