Sponsored by: Real Truck
super duty transmission
Old Mar 24, 2005 | 07:57 PM
muddyford75's Avatar
muddyford75
hey guys, i went wheelin today and gotto the very end of the trail and smelt tranny fluid. sure enough it was drippin out pretty good. i let it cool down and then it just let a few drops go...i noticed that it was dripping out of what looked like a small hole in the front of the transmission where it meets the motor. does anyone have any ideas on what this problem might be, or has had something similar happen? as of right now it runs, shifts and drives fine, but its better to be safe than sorry. any help would be greatly appreciated. thanks!
Old Mar 24, 2005 | 08:26 PM
wildcat421's Avatar
wildcat421
Which tranny is it .
Old Mar 24, 2005 | 08:37 PM
99f350sd's Avatar
99f350sd
Yes please tell us year , type etc. Sounds like a pump seal.
Old Mar 24, 2005 | 10:56 PM
elkman375's Avatar
elkman375
hey guys i was on my friends name thing when i posted.....i am not sure what tranny it is, but it is a 1999 1/2 7.3L diesel if that helps at all...
Old Mar 25, 2005 | 05:45 PM
trapperjonNY's Avatar
trapperjonNY
have no idea if this will help, but I oveheated a C-6 a few years back plowing and getting stuck, got 'ur out but she was leaving two blood trails for 500' up the drive, thought for sure it was gone. Parked it and let it cool dumped 2 qts. of type F in (est. loss) ck'd it 2 more, looked under with a grimmace on my face and to my suprise, no leak and the tranny for the next two yrs. was better than ever.
Old Mar 25, 2005 | 07:11 PM
J.C.'s Avatar
J.C.
Sounds like you overheated the tranny and it burped out of the vent tubes. I'm sure it wasn't the best thing you could have done to it but, I'd just change the fluid and filter and not worry about it. You also might want to consider getting a temp. gauge for your tranny so you don't do it again.
Old Mar 25, 2005 | 07:56 PM
stereorion's Avatar
stereorion
Thanks, I never knew there was an overflow for the tranny. I had a Ranger and everytime I would tow my boat, and it was hot out, it would blow all kinds of tranny fluid out. Then once it cooled down it wouldn't leak a drop, until the next time I would tow my boat.
My new F-250 pulls it like nothing.
Old Mar 26, 2005 | 02:22 AM
elkman375's Avatar
elkman375
thanks guys that helps a ton. i think ill do as JC said and get a gauge....i was just worried that it was gunna be a new tranny and i definetly dont have the kind of money haha. thanks guys, ill keep yall posted!
Old Mar 26, 2005 | 09:04 AM
J.C.'s Avatar
J.C.
Also, if you find you have a continuing problem with overheating you could upgrade to a radiator from a later model super duty. The 99's only had the air to water cooler for the transmission whereas they later upgraded to having both the air to water cooler and a cooler integrated in the radiator. I can't remember the year but I think the change happened for 00, 01 at the latest.
d2hornets
Mar 2, 2014 12:01 PM
mudrat025
35
Sep 24, 2013 01:35 AM
bullman2009
Jul 8, 2011 10:29 PM
V8 Andy
Mar 28, 2006 01:35 AM
shunshine X
Mar 24, 2003 08:30 PM
