Suspension Noise? help?
Old Mar 24, 2005 | 06:53 PM
StylinGirl's Avatar
StylinGirl
Question Suspension Noise? help?
My dads asked me to go check out a noise in his truck for him (98 explorer sport AWD)
it happens from about 25-35mph
to me it doesnt sound like a bearing.. or ball joint..
u know the sound your tire makes when its got something sticking out of it?
thud...nothing...thud...nothing (sorry lol thats the best i can think to explain it)
well it is kind of like that... but its not a loud thud, and theres no silence in between, theres a sound that SOMEWHAT resembles what a bad bearing would sound like but a really low tone. but its quieter than the "thud" sound
and it appears to sound worse when i an turning to the right....
so it kinda sounds like this in a low tone..
hmmmmmmmHMMMhmmmmmmmHMMMhmmmmmmmHMMM
does that make sense? i dont know how else to explain the sound LOL
let me know what you guys think? Thank u
Old Mar 24, 2005 | 08:21 PM
JerrySimm's Avatar
JerrySimm
Since it's AWD, I would wonder about the front axle CV joints. May be worn an popping, and it would be worse when turning.
Old Mar 25, 2005 | 08:29 AM
StylinGirl's Avatar
StylinGirl
nothings really popping...
its a really low sound that resembles a bad-bearing sound.. but is louder almost thudlike at a certain point in the wheels rotation...
its only above 25mph and nothing sounds loose in the suspension when im going over bumps.
i know for a fact it needs shocks but i highly doubt that would attribute to this noise...?
Old Mar 25, 2005 | 01:55 PM
my91EXP's Avatar
my91EXP
Smile
Hi Stylingirl,
If this truck has standard universals on the outer stub-shafts to the rotors, it could very well be a set of the roller-bearings in one of the cups (or all) on one of the U-Joints. The sound your describing, with the timing, and the heitened volume, etc., is usually indicative of a U-Joint piling up.
This is usually due to lack of service/greasing. The fix is pretty straight forward. I'd recommend you grease the joints (if they're the servicable type) and see if that eliminates the symptoms, if it does, then replace the joints because they've already failed and greasing them is only a temporary fix.
Incidentally, there's a possibility that it's a drive-shaft U-Joint as well, so you may as well service/grease them to.
Hope this helps...
Shipster
Apr 16, 2014 02:24 PM
AKPetrohead
Aug 8, 2011 11:16 PM
Julies Cool F1
15
Mar 1, 2010 06:50 AM
aristocraft
17
Feb 25, 2010 10:33 AM
