Hello Everyone
Old Mar 24, 2005 | 11:38 AM
enderfd13's Avatar
enderfd13
4wd High
Exclamation Hello Everyone
Hello FTE!
I'm new to the forum as you could tell. I'm having some troubles finding a forum about vehicles 98 and older. I have a 96 Explorer. My check engine lights came on the other day and comes on every time I start it. I ran the self system check the explorer has and it said everything is okay. Any ideas?
Old Mar 24, 2005 | 06:44 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Please read this.. https://www.ford-trucks.com/forums/s...d.php?t=300691
Go to the main page and scroll down or
https://www.ford-trucks.com/forums/f...splay.php?f=32
We are happy you have chosen the best source for Fords!
Enjoy FTE and
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. ….
Old Mar 24, 2005 | 09:06 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to Explorer forum.
Old Mar 24, 2005 | 09:54 PM
texan2004's Avatar
texan2004
Your local auto parts store should be able to pull the code for you, usually for free. If not, most decent independent sp shold be able to pull the code and there's always the dealer. It could be jst about anything. When mine did this it was the O2 sensor.
Old Mar 24, 2005 | 11:53 PM
enderfd13's Avatar
enderfd13
4wd High
Alright thanks. I'll try that.
Old Mar 25, 2005 | 03:55 AM
marragtop's Avatar
marragtop
By all means, get the codes pulled and post them here. Are you having any other problems with the way it is running?
Old Mar 25, 2005 | 12:23 PM
99Xplr's Avatar
99Xplr
Autozone will pull the codes for free.
Give them a call first to make sure they have the scanner.... most share a scanner between stores.
Let us know what the codes are so we can help you fix the problem.
Old Mar 25, 2005 | 12:49 PM
marragtop's Avatar
marragtop
As 99X said, Autozone will pull the codes for you. They will also try and sell you the parts at the same time. I suggest posting the codes here before buying the parts.
Old Aug 3, 2005 | 01:56 PM
enderfd13's Avatar
enderfd13
4wd High
the code read for an oxygen sensor. and he said it was on the front passenger side, but got under the vehicle and found the driver side sensor. i changed that one and it was still on Auto Zone said you guessed it "that is the driver's side not the passenger" anyone know where the passenger's side sensor is?
Old Aug 3, 2005 | 02:00 PM
bulldog3531's Avatar
bulldog3531
When you changed the sensor did you disconnect the battery to reset the computer?
Old Aug 3, 2005 | 08:42 PM
don96exp's Avatar
don96exp
I have '96 with the 5.0V8 and the passenger side O2 sensor is located in the exhaust pipe between the exhaust manifold and the catalytic convertor. It's mounted on teh top of the exhaust pipe, I used the offset O2 socket fron the local auto store.
Old Aug 5, 2005 | 12:56 AM
enderfd13's Avatar
enderfd13
4wd High
hm.. my father and I found the O2 sensors. Well, I should say sensors.. for which there are two right next to each other and one behind a little. I have a few questions. Should the front two on the passenger side be crossed? this is hard to explain.. the front sensor was plugged into the back of the other end. and the back sensor was plugged into the front of the other side.. hm.. that didn't really make sense. just think of a X. that's how they were plugged in. now. my questions are, 1. which is the Bank 1 sensor 1. and 2. how do we take it off. we got up under and I could get one arm up to it, but couldn't manage to get my other up there to pull. we took off the tire, as well as the splash gaurd. no go.. is there some tool? or another way to get up there?
