I feel a bit annoying that wiper (driver side) didnt reach to farther drivers windowsheild.
can i adjustment the wiper on driver side to make it reach farther driverside windowsheild so it ll gain better visual?
Theres 3-5" room space on windowsheild that i think i can try to adjust and make it reach driver side roof frame by windowshield
Thanks!
YOMAN!
Yes you can. I had the same problem on my 04 scab. Remove the wiper arm and take the key out of the spindle. You can then reattech the arm at the proper height. Someone said it might jump a tooth or two in the snow without the key, but I did mine last year and had a fairly wet winter here in NY and so far no problems. I cant believe Ford does not address this as it is a line of sight issue that could be dangerous. Good Luck
You can also swap the left for the right. The arms are bent different and this will give you the coverage you need. Puts the wiper about an inch from the drivers side pillar.
