diesel power steering, how does it work?
Old Mar 24, 2005 | 09:54 AM
Delawhere?'s Avatar
Delawhere?
Question diesel power steering, how does it work?
I have a question that pertains to a problem a friend had happen to him. His power steering locked up and the wheel would not move. This happened as he started the 6.0L dsl. and was attempting to move his travel trailer first thing in the morning. It was only after moving the truck forward and backward that the steering wheel was able to turn normally. This is on a 2 wheel drive F250 long bed.
Does the diesel engine have a power steering pump like most vehicles, or is it different than gas engines? Is it vacuum controlled or have something to do with vacuum that the engine has to run at a higher RPM to get it to work properly when it has been idle for a period of time?
Hopefully someone can explain this as I was not able to find anything in a search of power steering that was related to diesel motors.
Old Mar 24, 2005 | 12:27 PM
wolffee's Avatar
wolffee
I belive its hydro assited and shares the hydro asst. with the brakes. So if he had his foot planted on the brake or on the brake with any force it can he hard to turn the wheel when the truck is not moving. I belive The Brakes and the power steering share one power asst booster. I had the same problom when in a parking lot the wheel would get reel hard to turn if i wasnt moving and had my foot on the brake. When i heard this went outside and was right. Hope this helps and again i belive this is how it works i could be wrong its just what i was told. you know how that goes.
ryan
Old Mar 24, 2005 | 12:32 PM
MRKnight's Avatar
MRKnight
Does this apply to the '05 model? I've always wondered why sometimes my power steering would feel like it's binding when I'm sitting still in my steep driveway - with my foot buried into the brake pedal
Old Mar 24, 2005 | 02:09 PM
wolffee's Avatar
wolffee
I cant say for sure on an 05 mine is an 04 but i havent heard that they changed anything in that system from year to year. If its all the same then that would be the reason. Its not to be concerned with ford told me and it does make alot of sense why the wheel would have a loss of power steering if it needs the hydro asst. but your using it to hold the brakes... makes sense but still it should have 2 i think one for each.
Ryan
Old Mar 24, 2005 | 02:46 PM
EnviroCon's Avatar
EnviroCon
Ryan- I'm pretty sure you're right about the steering mechanics. I remember reading a TSB about steering column noises. One of the checks they recommended was the hydraulic line that runs from the brake hydro boost to the steering system. But completely locking-up the system? I can see it making it hard to move, if the systems low on pressure from brake usuage, but that sounds like something may have come loose and physically prevented the steering (wheels, column, tie-rod, drag link, etc) from being turned. This one's kind of a mystery. The only other reason I can think of to cause the steering wheel to not want to move is the ignition lock.
Old Mar 24, 2005 | 02:56 PM
dsweger's Avatar
dsweger
Is it possible that the steering column ignition lock was hung up?
Old Mar 24, 2005 | 03:12 PM
Delawhere?'s Avatar
Delawhere?
no the steering column ignition lock was not the problem, the truck was running and his wife had her foot on the brake as some have already said could be part of the problem. The truck was just started and were attempting to move the trailer to remove the chocks and the steering wheel just wouldn't move. After a few movements fore and aft and possibly building up some rpm's the steering wheel again was functional. This has happened on a few occasions but does not happen enough to warrant a service call.
Just would like to understand how the system works so as to know why it does what it does when it does.
Old Mar 24, 2005 | 03:55 PM
EnviroCon's Avatar
EnviroCon
6literpowerstroke/cgi-bin/ubbcgi/ultimatebb.cgi
It's still early in the day so I'm sure later on more people will respond. But, you may consider, I feel kind of dirty saying this, because this is my favorite site, posting your question at:
http://flatratetech.com/6literpowers...ultimatebb.cgi
The site's run by Ford Techs. They may not get back to you right away, but they usually respond. It's also a great place to get an OASIS report.
I wish I could go out to my truck and look, but it's in the shop with a mystery oil leak.
