Leaf springs
Old Mar 23, 2005 | 09:11 PM
BIG PAT's Avatar
BIG PAT
Leaf springs
Hi
I have a 1985 f-150 with a 300, 4-speed granny tranny, 9" rear with a posi and 3.50s.
I just recently did a 4x4 conversion on this truck.
On the rear i opted to keep the original 3.5" wide leaf springs (the 4x4s have 4" wide). The bottom spring is twisting sideways of the other springs. It is doing this because the u-bolts are 4" apart and dont hold it anymore on the sides.
I made some clamps for them today to keep them straight but they squeezed all the leafs together and stiffined them up considerably.
Is this ok? Any other suggestions?
Thanks
BIG PAT
Forgot to mention I had to pull out my dads brand new 3/4 ton chevy 4x4 truck the other day. Ha Ha
Old Mar 23, 2005 | 09:27 PM
MontanaFord's Avatar
MontanaFord
pat...my 84 f-150 4x4 is all stock, and the leaf springs on it are only 3" wide....just thought i'd mention that...
MontanaFord
Old Mar 24, 2005 | 09:25 AM
BIG PAT's Avatar
BIG PAT
Thanks
In that case i will go and try to find some 3.5 inch lift blocks so i can bring the u-bolts closer together.
BIG PAT
Old Mar 25, 2005 | 02:32 AM
MontanaFord
somethin else, too...i doubt that your truck came stock w/ the 9"....ford quit the 9 inch for the most part, around 1983, from what i've been told, and went to the 8.8" rear...you're certain yours is a 9"?? 8.8" has a rear pan on the differential...9" don't...
MontanaFord
Old Mar 25, 2005 | 09:31 AM
BIG PAT's Avatar
BIG PAT
My truck did not come with a 9". It had a 8.8. I put the 9" in during my 4x4 conversion. Ford did stop using the 9" around 83.
Thanks BIG PAT
