1999 Expo EB edition
Old Mar 23, 2005 | 04:04 PM
urs1's Avatar
urs1
Air Level, some times my truck Rt Rear drops over night and other times the whole truck leans to the Rt side (both front and back). Checked for air leaks, none found. All thinks check ok. When I stat the truck, they pump up and the air Comp very rarely comes on again.
Also my service eng soon light comes on, just after 100000 mi.. !Checked an con find any bad sensors.. Reset it and comes on abort 50 milater. Checked again,code said its is lean. what does that mean, all sensor checked ok,, whatr would a does a leaky gas cap cause? All O2 sensor check ok. ir sensor was cleaned and checked ok too.
Keyless entry pad, did work, now the factory code does not open doors, Thought it was blown fuse, but I can lock the door by using the pad. Any help?
URS1
Old Mar 24, 2005 | 03:05 AM
NoMo's Avatar
NoMo
Welcome to the site!
Sounds like one (or more) of your airbags has a slow leak. Not too uncommon considering the age & mileage of your vehicle. Options are to "live with it", replace the leaking bag(s), or swap the air suspension out with the standard suspension.
On the "lean" code... look a few posts down- there is a thread discussing this very issue.
Not sure what to do about your keypad. Sounds like the keys are working and the wiring is OK. Have you reset the computer lately?
79f100six
Sep 16, 2016 07:51 AM
rogerranger2122
1983 - 2012 Ranger & B-Series
23
Aug 8, 2016 06:24 PM
Mr f250
Feb 21, 2016 11:25 PM
jbourne84
Feb 2, 2016 07:06 AM
Dusty Noble
Oct 3, 2014 11:50 AM
