3rd Brake Light ???
Old Mar 23, 2005 | 10:47 AM
mt54's Avatar
mt54
3rd Brake Light ???
I’d like to french in a third brake light. Anyone have ideas on what light to use, and where to get one, I’d like it to be on the slim side nothing real big, poss. LED.
Any thoughts will help
Thanks
Mike
Old Mar 23, 2005 | 11:45 AM
LEckart's Avatar
LEckart
There are several suppliers of LED 3rd brake lights that you weld in. Some to check out are Lambert Enterprises, Hagan, and Watson's Streetworks.
Old Mar 23, 2005 | 11:47 AM
Matt Scassero's Avatar
Matt Scassero
Classic Trucks magazine did a piece on this very thing a few months back, maybe fall 04 sometime. I'll see if I can find it. Very nice install.
Matt
Old Mar 24, 2005 | 09:30 AM
53Merc's Avatar
53Merc
Thumbs up
Thanks
Mike
MT54,
I did this to my '53 Mercury M100... I believe it was a Hagan's unit I used.
The finished product reveals a 1/2" x about 10" bright LED light.
The "kit" comes with the LED and a prefabed metal housing ready for grafting into the location of your choice.
The slim LED is slightly camphered [sp?] and angled at the ends...it's a trapezoid I guess.
I grafted mine in above the back window and the trapezoidal angles mimicked the curvature of the cab roof line nicely I thought.
I'm not sure if there's a picture with enough detail in my gallery but there are some pictures that show it.
GW
Old Mar 24, 2005 | 09:43 AM
53Merc's Avatar
53Merc
Lightbulb
Originally Posted by 53Merc
MT54,
GW
There are at least two pictures in my galleries of the rear of the cab...the detail of the openning for the 3rd brake light shows up best in the picture of the cab in scabby old primer!
GW [& the Dixie Dance Kings!] in the Great White North for Easter
Old Mar 24, 2005 | 09:52 AM
mt54's Avatar
mt54
Thanks for the info guys.
Mrec, from what I can see in your gallery that looks about what I'm lookin for, However I was thinkin maybe mounting under the rear window ?? not sure yet.
Also I was wondering if anyone had any luck finding a donor light from other vehicles, and grafting it in.
Mike
Old Mar 24, 2005 | 10:20 AM
Huntsman's Avatar
Huntsman
I saw an interesting addition on a new SUV in town the other night. It was a very thin row of LED lights that fit in the thin gap between the top of the bumper and the tailgate. Totally unnoticeable until they lit up.
With the right turn signal on, the left light lit up and ran across to the right end until all were lit and it repeated with each blink of the regular tailight. When the brakes were applied, the left half of the strip lit up solid and the LED in the center lit and ran to the right end. Very bright/impossible to miss, thought this might be a nice addition to the relative low visibility of the stock ford tailight, and the fact I was almost rearended the first and only time I drove it before I tore it apart, almost five years ago.
Old Mar 24, 2005 | 01:29 PM
Jag Red 54's Avatar
Jag Red 54
Mike, have you seen the "Line of Fire"? It is similar to what Huntsman is describing except for the animation. It mounts below the tailagate and hooks up to the standard rear light wires. It is about 1" shortwer than your tailgate. When you turn the blinker on, then that half (20 led lights) flash with your regular blinker. If you hit your brakes, then all forty light illuminate simultaniusly! At night all forty are on dimly, then brighten when you hit your brakes or blinkers. So it behaves just like your blinkers and emergency flashers. They are about $80 including shipping. I put one on my truck last year and it has made CA driving a little less risky. Jag
Old Mar 24, 2005 | 01:38 PM
fatfenders56's Avatar
fatfenders56
I made one from flat red plexiglass and backed it with the pyramid texture clear from an old flourescent light fixture, backed it up with some led's from the Kenworth truck dealer ($12.00) lights up like a christmas tree and you can make it any size or shape you like.
Old Mar 24, 2005 | 01:59 PM
jniolon's Avatar
jniolon
old and in the way
Mike,
this is the only pic i have online of mine...under the window..
I bought a Julianos led unit about 12" long and ½" high...
I can take some later shots if you need them...
john
Old Mar 24, 2005 | 02:03 PM
mt54's Avatar
mt54
Jag, I've seen the line of frie light,just a little bigger than I'm lookin for
FF56, that idea sounds like it may work for me, I'll have to look into suplies in my area.
John, that looks great almost the exact look I'm goin for.
Thanks
Mike
Old Mar 24, 2005 | 03:50 PM
53Merc's Avatar
53Merc
Thumbs up
Originally Posted by jniolon
Mike,
john
Hey John, Do you have a recent pic of your ride?
BTW, I hope Cole and his parents are well.
Said a little prayer for them when I saw your post.
GW
Old Mar 24, 2005 | 05:38 PM
AXracer's Avatar
AXracer
Check the ads in Street Rod magazine there are several companies that make led lights in a variety of configurations and some have preformed metal buckets to weld in.
I like best the ones that have a thick plastic lens that you sand to the body contours after mounting so they're perfectly flush. Have seen where you can even get a stealth appearance by removing the masking over the lens before you spray on the last color coat. You can't even see them until they light up and shine through the paint.
I would suggest mounting above the window rather than below. I drive a Miata and wouldn't even be able to see the lower 1/2 of the back window from a few car lengths back.
They offer some that fit in the end of the rolls at the top of the bed sides too.
Old Mar 24, 2005 | 08:18 PM
fatfenders56
Mike, don't know where you are in the great state of pencil-vane-a but if you are anywhere near Hershey see Posies, he/they are old hands at the plastic thing. ,good luck, keep us posted
