Thread size on defroster duct nuts!
Old Mar 23, 2005 | 10:29 AM
theGman's Avatar
theGman
Help! Paul's fat fingers dropped and lost one of the nuts attaching the drivers side defroster duct. It is too far up to play matchy-matchy with, so I was wondering if anyone knew the size/thread pitch?
I had to take out the drivers side duct in order to modify (cut a chunk out of the left middle and fill with duct tape) so my that the upper left gauge on my new 5- gauge/dash panel would clear. Upon installing, I got one nut of the two on, but one fell into the black hole we jackstand warriors know so well.
Thanks, Paul
Just thinking, I should get my name changed from "pgayda", which really plain, to "fatfingers", which fits my mechanical ability.
Old Mar 23, 2005 | 02:02 PM
AXracer's Avatar
AXracer
I don't know for sure since I didn't drop mine but I'd guess a 10-24. Just go to the hardware store and buy a few of each size from 6 to 12 then you'll have extras for the next time you make a deposit into the nut bank. Add a star washer under the nut so you don't have to replace it again from vibrating loose.
PS: Duct tape won't hold long in the warm air unless you use the metal foil type, not the cloth stuff. A simple metal patch formed from aluminum roof flashing stock (soft and thin shape with your fingers, cut with scissors) Pop-riveted on and sealed with silicon caulk would be a far more permanent fix. Fix it now and you won't have to pull it out again later.
Old Mar 23, 2005 | 05:08 PM
theGman's Avatar
theGman
Thanks for the info; unfortunately I will have to fix it later, since the instrument panel is installed. For what it's worth, I did this same mod, but a smaller hole, on the same duct in 1998 and the duct tape was still holding up fine. Of course, I know that duct tape is a temporary patch at best.
I was trying to get the exact size, but I have some trial fit nuts. I imagine it is a fine thread like about everything else on the truck.
Old Mar 23, 2005 | 05:27 PM
AXracer's Avatar
AXracer
I thought about that before I first answered but I seemed to recall it was a course thread. Fine thread would be a 10-32.
Any cloth duct tape I've used deteriorated rather quickly especially when exposed to heat, maybe you have found a better grade.
Old Mar 23, 2005 | 05:30 PM
Randy Jack's Avatar
Randy Jack
Thegman -
I would have answered earlier, but I needed to measure it after I got home from work. I have the duct out of my 56 also.
It is an 8-32 thread. The stock nut has a star washer on it.
Old Mar 23, 2005 | 05:32 PM
AXracer's Avatar
AXracer
I was close! I remembered the attached star washer that's why I mentioned it.
Old Mar 23, 2005 | 08:36 PM
theGman's Avatar
theGman
Thanks a lot for this small requst. Paul
Old Mar 23, 2005 | 08:37 PM
theGman's Avatar
theGman
Oops. "request"...these fat fingers must be tied to a lame brain sometimes
