glowplugs
Old Mar 23, 2005 | 09:37 AM
dieselfreak's Avatar
dieselfreak
glowplugs
ok, im pretty sure my glow plugs are shot so im just going to replace them. plus, it will make my dad happy. so is this difficult or simmilar to changing spark pligs on a gas job. do you have to prime the system?
Old Mar 23, 2005 | 10:46 AM
Spectramac's Avatar
Spectramac
The second ones back on both sides are a little tricky, they're under the fuel lines. Does this truck have a turbo? That can make it a real chore.
Old Mar 23, 2005 | 11:30 AM
lcampbell's Avatar
lcampbell
When you do them, you may have to remove the injector lines above the plugs. If you do, only do 1 plug at a time.
Old Mar 23, 2005 | 12:11 PM
PLC7.3's Avatar
PLC7.3
First visit Ziggsters page for some eye opening info...
cut and paste it........... http://www.members.shaw.ca/k2pilot/
This is what I recommend as a proceedure for GP R&R....remove air cleaner if IDI.
To remove/replace gp's get a 3/8" 6point deep socket and suitable ratchet, 8" piece of gasline hose that will fit on top of gp. Remove gp electrical caps blow or brush clean each area around gp's, lossen gp with socket until it turns freely remove socket and push hose on top, turn out gp. For the one under the injector lines on drivers side you can use a universal joint (hard) or a 3/8 box end wrench then the hose as usual (do not force or bend lines) Test GP's and check tips.
If you have it put (small amount) anti sieze on threads of new gp, you can use hose to start plugs then finish with ratchet to 12 ft/lbs or 1/12th of a turn after bottoming( this is not much torque at all)
If I were you, I would remove all gp's to see what kind they are, if they are not "BERU/Motorcraft" pitch them and buy all 8 new, if they are Beru and test good re install. If some are bad get 8 new and save old ones that are good for backups.
NOTE***If any GP's are hard to remove from hole "STOP" call for assistance and wait for instructions.
PS A big old blanket over the rad helps in laying on the engine.
Old Mar 24, 2005 | 08:41 AM
dieselfreak
hey everyone, thanks for all your responses, i really appreciate it. it should be a lot easier now
