Random hard brake pedal
Old Mar 22, 2005 | 10:16 PM
Ringer's Avatar
Ringer
I have a 97 f250, 7.3 powerstroke diesel and have noticed that every once in awhile I would have limited brake assist. Lately it has been happening more and more. They work fine when they do and I get a hard pedal when they don't. I checked the vacuum lines and they seem ok, I can't find any leaks.
Any suggestions on where, or what to look/check for? Any tips on narrowing down the problem before I start replacing parts?
Old Mar 23, 2005 | 12:58 AM
Ggg6's Avatar
Ggg6
Sound like your vacuum pump is going. Put a vacuum gage on it, the vacuum should be a steady 14 or more in.Hg. less then 14 or fluctuations are bad.
Old Mar 23, 2005 | 05:57 AM
blackf3504dr's Avatar
blackf3504dr
Yep , I have to agree with Ggg6 on the vacume pump going south .
Old Mar 23, 2005 | 11:11 AM
Ringer's Avatar
Ringer
Thanks, Ggg6 and blackf3504dr, I'll do the vacuum check and take it from there. If it is the pump, is it something the average guy can change out or is it a dealer thing? (special tools etc?)
Old Mar 23, 2005 | 11:26 AM
Max1775's Avatar
Max1775
Vacuum pump should be fairly easy to replace. Kinda like changing out the alternator.
Max
Old Mar 23, 2005 | 11:37 AM
Ringer's Avatar
Ringer
Thanks Max
Jrobole
Jul 5, 2016 11:33 AM
cr506
18
Apr 8, 2010 08:16 PM
fromm
1978 - 1996 Big Bronco
30
Jul 3, 2009 07:31 PM
timbersteel
Nov 22, 2006 05:42 AM
Gschroer
Aerostar
Nov 13, 2001 08:55 AM
