leaky rear end..?
Old Mar 22, 2005 | 03:43 PM
96ranger_dallas's Avatar
96ranger_dallas
leaky rear end..?
i just happened to look down at the rear end of my ranger and it looks like the bottom half is drenched in fluid..? but there is no leaks on the floor at all...? any idears?, thanks mike
Old Mar 22, 2005 | 06:53 PM
el conquistador's Avatar
el conquistador
clean it up and try to get spot the leak, if any.
Old Mar 22, 2005 | 07:41 PM
G2IC_Wraith's Avatar
G2IC_Wraith
Yea, I don't know that you will see any on the floor. Gear oil is really thick and only tends to leak when it is hot and under the built up pressure of driving.
Old Mar 22, 2005 | 08:11 PM
Ken00's Avatar
Ken00
Sounds like the pinion seal, in most cases fluids will travel down and towards the rear.
Old Mar 22, 2005 | 09:00 PM
vulch's Avatar
vulch
it could be the vent hole is pluged it happened to my 89 ranger it was leaking at the pinion seal the hose that is connected to the vent was cracked and the vent was blocked cleaned it out no more leak
Old Mar 24, 2005 | 08:43 AM
96ranger_dallas
thanks guys i will check that out.
Old Jun 20, 2005 | 09:18 AM
Zaurusman's Avatar
Zaurusman
How big of a deal is it to get to that pinion seal and replace it on a '96 2wd?
Old Jun 20, 2005 | 10:14 AM
G2IC_Wraith
I would replace it when you can. Untill then I would just make sure you have enough gear oil in there. Unless the leak is REAL bad you should be fine.
Old Jun 20, 2005 | 10:17 AM
Zaurusman's Avatar
Zaurusman
Ooops - I think I typed that wrong. How big of a job is it to replace the pinion seal? I'm thinking about doing it myself, and if not, wanna know what I ought to expect to pay for the repair.
Truck's got 147K miles, so no warranty.
Thanks!
Old Jun 20, 2005 | 10:37 AM
G2IC_Wraith
I have never done one that I can remember, but I can imagine is too hard. If you don't have a Haynes or Chiltons I would suggest getting one. They do the best they can at step by step repairs.
Without mine infront of me I'd say dropping the drive shaft is no big deal. Removing the pinion yolk bolt is probably a pain, and you will likely need some sort of seal puller/installer. Just guessing. The part should be cheap, it looks like it is $15-$35 depending on what brand you get at Advance Auto. If you had a shop do it you should expect 1/2hr to 1hr labor. If they want anymore, the guy is REALLY goofing off under there.
Welcome to FTE.
Old Jun 20, 2005 | 12:21 PM
Zaurusman's Avatar
Zaurusman
Thanks! While I'm on here, where do I refill it? On my Dodges there's an obvious plug on the diff cover but I don't see one on this one.
Old Jun 20, 2005 | 12:40 PM
G2IC_Wraith
Different models may have different locations, but mine was on the passenger's side of the differential above the driveshaft. It might have a lot of junk built up on it. If you can't find one, you shold at least have a vent tube or breather of some sort. I have seen guys fill from there too.
Old Jun 20, 2005 | 12:42 PM
Zaurusman's Avatar
Zaurusman
Cool. Thanks again for your help. 'Preciate it.
