ranger overheating
Old Jun 20, 2005 | 07:51 AM
knuckle frank's Avatar
knuckle frank
ranger overheating
got a 2000 ext cab and on the freeway with the a/c on bot 65mph the temp starts climbing un the mid and hot and i can feel a roughness in the ride, then the a/c goes warm. arround town allday at 40-50 mph with the a/c on everything is ok.
whats my areas.
restricted radiator?
restricted thermostat?
a/c compressor drag?
fan clutch?
Old Jun 20, 2005 | 08:56 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
Engine size?
Factory A/C or dealer installed?
Ambient Temperature?
Old Jun 20, 2005 | 10:52 AM
knuckle frank
v6, factory air, 105 deg outside,
it only gets hot on the freeway and not sitting or city traffic
it dont boil over and when I cut the air it receeds a bit but not to normal centered in the guage
Old Jun 20, 2005 | 11:02 AM
DetailerDave's Avatar
DetailerDave
With engine off and cooled down, and no pressure in cooling system, try to squeeze the lower radiator hose along it's length. It should not be able to squeeze shut anywhere. Also make sure your belt tensioner still has some travel left, and the belt is not stretched to the limit.
Old Jun 20, 2005 | 11:24 AM
knuckle frank
I'll try that as soon as it cools down,
thanks
Old Jun 20, 2005 | 02:54 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I assume that the A/C condensor is not plugged with bugs and the like, thus restricting airflow.
Old Jun 20, 2005 | 03:53 PM
knuckle frank
as before as soon as it cools down from the last drive I'll check that also
thanks
