Mass Air Sensor?
Old Mar 22, 2005 | 11:06 AM
Hallz's Avatar
Hallz
Question Mass Air Sensor?
Hey guys,
I was wondering if anyone would know the answer to a question that is troubling me. I am doing a motor swap and it is becoming a large mix of parts and years. First off the motor and 90% of everything is from a Mustang 95GT. The vendor I bought my harness recommended to switch to a 89-93 Distributor, Computer (A9L) and Mass Air.
Here is the heart of my question. I am wondering if the Mass Air from the 95 would be better suited since it is a complete 95 motor, throttle body to oil pan. Will it even work with the early computer? I know the plug is the same,..but thats as far as I can tell.
Thanks
Old Mar 22, 2005 | 11:14 AM
divit250r's Avatar
divit250r
I think that as long as the mass air sensor is sized correctly for the injectors (stock 19lb injectors, stock MAS) it shouldn't matter what year it is. When I bought my ProM for my 95 Mustang, all they needed to know was the number of pins in the connector, connector shape (Oval, I think), and injector size. Hope this helps.
Scott
Old Mar 22, 2005 | 12:24 PM
EPNCSU2006's Avatar
EPNCSU2006
If you are planning any type of modification to the engine, I would strongly suggest using an '89-'93 computer (A9L for manual transmissions is the most common). They are much more forgiving with engine modifications, whereas the '95 is very sensitive to changes from the stock configuration.
http://fordfuelinjection.com/files/A...0_showdown.doc
http://fordfuelinjection.com/files/E...r_Workings.pdf
there are a couple references that might interest you
Old Mar 22, 2005 | 12:51 PM
Hallz's Avatar
Hallz
I did get the A9L as Ryan suggested, along with the Distributor. I will be moding it once it is all up and running.
The only thing left is the MAF, Exaust and a new flexplate and a few small items. Such as extending and re route a few of the connections.
I am just wondering if the 95 MAF will work with the A9L?
Old May 14, 2005 | 12:14 AM
chipndale63's Avatar
chipndale63
As long as all the parts are of the EEC 4 vintage you shouldn't have any problems putting it all together, Good luck.
Red Voodoo
New Member Introductions
Mar 10, 2014 05:05 PM
Barrie guy
6.7L Power Stroke Diesel
35
Aug 5, 2013 02:42 PM
bcurrey
1983 - 2012 Ranger & B-Series
Sep 1, 2012 09:54 AM
MrNord
33
Nov 8, 2010 07:33 PM
66chevelle
Mar 20, 2008 10:11 AM
