1939 hood latch
Old Mar 22, 2005 | 09:09 AM
JnJO39's Avatar
JnJO39
1939 hood latch
After about 1 -1/2 years I am almost ready to start putting my 39 pick up back together. One thing that is missing is the hood latch hadware. I have the hood ornament, but I don't believe I have any of the hardware including the latch. Can someone tell me what I am looking for? I don't think I ever had the parts. Can someone provide a drawing or provide a reference for how the hood latches. I know there are a couple of plates and a spring, but I am no sure how they go together
Thanks
JNJO39
Old Jun 6, 2006 | 09:14 PM
jadc7777's Avatar
jadc7777
1939 hood latch
JnJO39,
I am also restoring a 1939 Ford pick up and have the exact question about the latch. Will you let me know what information, if any, you get on this. I really appreciate your help!
Thanks,
Jadc7777
Old Jun 8, 2006 | 04:17 PM
JnJO39's Avatar
JnJO39
jadc7777,
This was a big issue for me. First there is a round to oval piece that fits on the bottom of the shaft of the hood ornrment. It an odd piece , more oval than round with an edge that slides in the retainer on the radiator shell. This is very important that the correct piece be used or the hood will not latch properly. I tried to make one, butit was not heavy enough and had too much play. I finally found one at a swap meet. I think a 37 car latch will also work, but a 38 truck will not work. It took me somtime, but I found one. I suggest you look at different swap meets.
If you want to get the hood right and want to use your hood ornament you need this piece. I could not find an aftermarket one so you just need to keep looking.
I am glad you are doing a 39, not many left
JNJO39
Old Jun 9, 2006 | 12:37 AM
jadc7777's Avatar
jadc7777
Dear Jnjo39, Thank you so much for responding, every little bit helps. I will let you know how it works out. Repectfully Jadc7777
Old Jun 29, 2006 | 08:46 PM
speeddemon289's Avatar
speeddemon289
hood latch
hey i bought a 39 big truck would that latch work
skdutch
Dec 2, 2005 08:51 AM
JnJO39
1947 and Older Ford Trucks
Aug 13, 2005 07:39 PM
JnJO39
Jul 13, 2005 12:18 PM
