98 expy drive axles
Old Mar 22, 2005 | 07:17 AM
rmiskelly's Avatar
rmiskelly
98 expy drive axles
ok.. i have a 98 expy. the rear end was leaking so i got a gasket and the syntheic oil.. here is my problem. both of my repair manuals state there is a oil fill plug in the front side of the rear axle housing. i can not find that plug. i can only find a sensor that is near the top of the housing. if i take off the sensor i can fill it from there. but how much oil to put in to it.. both manuals state to put 5.7 pts of oil in.. which is almost 3 quarts. i can not feel the oil when i put my finger in the hole as stated in the repair manuals. so i put in another quart with is now 4 quarts or 8 pints. and still can not feel the oil. i have both tags from the rear axel housing.
tag 1
75w140 synth
oil only
tag 2
S 935 C-1
3L7.3 9 7.5 7H04
what gives.
Thanks for the help
richard
Old Mar 22, 2005 | 07:48 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 22, 2005 | 12:10 PM
The_ED's Avatar
The_ED
If it's like Fords other differential housings......the plug is on the right side of the housing (if youre facing the driveshaft side)...above the webbing of the housing. Sometimes it's a tricky angle to get to depending on your relative position. It should be a square-recessed plug...for 3/8ths rachet or extension to fit it. Your oil level should be just below that hole, any higher and it may blow out of the vent in the housing.
wpnaes
Dec 28, 2020 10:56 PM
BuzzKing
Apr 10, 2016 04:51 AM
pwjackson42
Jan 22, 2016 10:08 AM
74broncosport
2004 - 2008 F150
Feb 22, 2014 09:45 PM
oreocreaming
29
Jul 2, 2010 04:12 PM
