NC inspection
Old Mar 21, 2005 | 10:29 PM
ha2400's Avatar
ha2400
NC inspection
In reading the NC forum, i read that for 35 yr old vehicals a safety inspection is no longer required. Is this true?
Old Mar 22, 2005 | 05:02 AM
jowilker's Avatar
jowilker
Tis correct. Also my understanding that all of the newer vehicles up to 96 that lived in areas where their pipes were sniffed, will get safety stickers, with no more sniffing. Everything else will rely on the newer OBII.
John
Old Mar 22, 2005 | 02:00 PM
ha2400's Avatar
ha2400
so no more yellow tags huh.
Old Mar 22, 2005 | 03:19 PM
bshackelford711's Avatar
bshackelford711
yep true that i got rid of the tag on my hot rod 69 f-100 and cleaned the area that the sticker used to be real good. tinted the windows as dark as i could so now i am good to go
Old Mar 22, 2005 | 03:33 PM
ha2400's Avatar
ha2400
my 71 has got a yr to go. damn
Old Mar 22, 2005 | 03:36 PM
bshackelford711
good things come to those who wait
Old Mar 23, 2005 | 08:42 AM
Kazco's Avatar
Kazco
NC Inspections
I have been told by an inspector at Jiffy Lube that all cars before 1974 no longer need to get inspected. Vehicles from 1975-1995 will need the safety inspection (yellow Sticker). 1996 and above will get full inspection - obdII - plugged into computer not the old exhaust pipe.
Hope this helps,
Mike
Old Mar 23, 2005 | 10:13 AM
ha2400's Avatar
ha2400
so i won't get pulled over if i don't have a yellow tag on my truck
Aaron
Old Mar 24, 2005 | 02:42 PM
bshackelford711
you should not but you can go to the local DMV and they will print you a copy of this statement then put it in your glove box with the reg. just to make sure
thats what i did
