Serpentine Belt Install Question?
Old Mar 21, 2005 | 08:31 PM
Bad Company's Avatar
Bad Company
Based on many of your suggestions I'm going to carry an extra serpentine belt with me at all times. What tools do you folks recommend carrying in order to make the switch on some roadside?
Thanks for all your help.
Old Mar 21, 2005 | 09:08 PM
mjwhip2's Avatar
mjwhip2
Can't remember if its a 3/8 or 1/2" rachet(I have them both in the truck at all times) and possibly a small extension.
Old Mar 22, 2005 | 07:50 AM
jaymo2309's Avatar
jaymo2309
1/2" drive "breaker bar" will do the trick and is very easy to change.
Old Mar 22, 2005 | 07:57 AM
duallydawg's Avatar
duallydawg
Pliers if you have to remove the top Radiator hose like mine.
Old Mar 22, 2005 | 09:21 AM
Rancha9's Avatar
Rancha9
If you don't want to have to remove the top radiator hose to change the serpentine belt, there is a replacement hose that routes around the belt... I believe it is supposed to be for ambulances. Do a search for it, or maybe somebody that has done it can chime in with a part #...
Old Mar 22, 2005 | 09:30 AM
Craze's Avatar
Craze
Here's the part numbers I have:
(NAPA) 9066 (upper, over belt)
(Carquest) 22433 (upper, over belt)
cheers
Old Mar 22, 2005 | 11:49 AM
Bad Company
Great information. Thanks folks!
Old Mar 22, 2005 | 02:07 PM
westladog's Avatar
westladog
So how much do these cost compare to the dealer's price?
This is a stupid question but what happens when you driving and the belt breaks?
Old Mar 22, 2005 | 07:52 PM
dagren99's Avatar
dagren99
Smile Belt Breaking Loses...
No such thing as a stupid question...
AC, Power Steering, Alt & Water pump all quit when you lose the acc belt. Will also lose PS pump assisted braking. Biggest items of concern are the water pump & alt. Engine will overheat & batteries won't get charged. You can drive for a little ways to find a good spot to pull over & change it but, not far. The steering will be a little bit stiffer than usual witout the PS pump. If your pulling when it happens remember the part about the PS pump boost to the brakes. It'll take a bit of room to stop.
Hope this answers it,
DG
Old Mar 22, 2005 | 08:20 PM
RickyBR's Avatar
RickyBR
yea and if it just frays like mine did it makes a mess of your fire blanket on your hood.
Old Mar 22, 2005 | 08:41 PM
Saguaro_7.3's Avatar
Saguaro_7.3
Remember the good old days when motors had two or three belts? Now if a belt goes, everything quits turning.
Old Mar 22, 2005 | 10:34 PM
Kwikkordead's Avatar
Kwikkordead
DG
Yeah, like less than a mile. It's AMAZING how fast things heat up when the coolant quits moving.
Old Mar 23, 2005 | 07:45 PM
dagren99's Avatar
dagren99
Smile Serp Belt Replacement
I've been lucky, Never had one break on my truck. Cheap insurance to change them every 40-45K miles. Broke one on a E-series Ford U-Break it truck - Drove a couple of miles before it got hot but, the temp was like low 20's that day.
D
B-Ryan 02
Aug 14, 2023 05:40 PM
arctic10
Sep 20, 2007 06:55 AM
meck1
May 13, 2007 08:09 PM
BeckerSD
Jun 30, 2004 01:40 PM
Pastmaster
Jun 5, 2002 11:37 AM
