Brake lines
Old Mar 21, 2005 | 07:59 PM
dlhngrs's Avatar
dlhngrs
Brake lines
I am redoing the brakes on my 1969 F-100 and find that I need to fabricate some new lines. Does anyone know of a method or tool that facilitates bending of the steel brake lines. I would like to form the coils in the line going from the master cylinder to the pressure distribution valve. I have various bending tools for copper lines but find that these do not work very well for the steel lines.
Old Mar 21, 2005 | 09:38 PM
rainbowATF's Avatar
rainbowATF
I did the coils at the master cylinder by wrapping (rolling) the brakeline around a chunk of 3" PVC pipe; go slow and hold securely against pipe and it will come out good.
Old Mar 22, 2005 | 03:13 AM
Ford_Six's Avatar
Ford_Six
A good trick for improving brake response and feel is to use adaptors and make those lines 1/4". The more fluid volume, the better the brake feel. Home depot has a tube bender, so does Napa. I usually do the bends by hand, if you work it slowly a little at a time, you won't kink it.
Old Mar 22, 2005 | 01:38 PM
mblayton's Avatar
mblayton
Ditto on wrapping the line around a 2.5"or 3" cylinder I did the same thing when I converted my 69 to disc brakes works great.
Old Mar 22, 2005 | 04:13 PM
ha2400's Avatar
ha2400
they make a bender that looks like garden hose with a spring on the outside that works quite well.
Old Mar 22, 2005 | 06:56 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
benders
Ridgid Tools make high quality hand benders that can bend steel or stainless tube. Not cheap between $64 and $72 each but a quality tool that will last a lifetime. With professional results, comments from others, you'll be glad you purchased them in 1/4", 5/16" and 3/8".
Carl....=o&o>....
Old Mar 23, 2005 | 09:15 AM
rebocardo's Avatar
rebocardo
If you want to make a good investment, buy one that not only does 45 degree double flare, but, also the 37 degree -AN fittings found on the newer vehicles and accessories.
