59 Steering Column Removal
Old Mar 21, 2005 | 07:35 PM
spurredon's Avatar
spurredon
Question 59 Steering Column Removal
I have been getting ready to lift the cab off my 59 F500. I am basically down to just the steering column and a few other knick-knacks. I'm new to this vintage. The next generation truck has the joint that you can seperate where this critter is solid all the way to the gear box. Do I need to disconnect the complete gearbox and then separate the column on the bench? I can see the end cap on the bottom side but didn't want to take if off out in the grass if there was any other way around it. Will the gear and tube come out as a unit? The opening around the tube looks as if were big enough.
Old Mar 21, 2005 | 08:31 PM
mr4speedford's Avatar
mr4speedford
The box is rigid, because the sector shaft does not come out. The shaft runs up the column so disassembly for removal is not possible.
Pull of the pitman arm, unbolt the column from the dash and the frame. Then just pull the entire assembly up through the floor. Since your cab is stripped, You can leave the steering wheel on till its out of the truck if you'd like. It took me 20mins of wrestling it, to finally get it angled to come out, but its not too hard. -4speed
Old Mar 21, 2005 | 09:38 PM
Sixoh's Avatar
Sixoh
y'oughtta try that with a lowered truck with a 351M shoehorned in there and home made exhausts! There's a fine window of angle to get that thing up throught the floor!
Actually, I just took off my steering wheel and brought it down to the ground. Since your cab is stripped, and I'm assuming you don't have an engine, it's probably easy either way!
Old Mar 21, 2005 | 09:45 PM
51ford fan's Avatar
51ford fan
If your planning to replace it take a sawzall and cut it off just above the floorboard and drop the steering box out the bottom.
Old Mar 22, 2005 | 07:46 PM
spurredon's Avatar
spurredon
You guys are great. Three ways to do the job. However I still don't have it out. I must admit that the sawzall idea sounded pretty tempting this afternoon when I was struggling with the awkward thing. I have it all unhooked from the truck but can not get it out and up thru the whole. I tried to beat Mr 4speed's time of twenty minutes but I had to give up when it started getting dark since it is sitting outside. The engine is still in the truck and I seem to be hitting on the side of the bell housing more than any thing else. At least it is unhooked and moved up out of the way. Sixoh's idea of going out thru the bottom sounds cool also.
Old Mar 26, 2005 | 12:13 AM
Glackowitz's Avatar
Glackowitz
I have pulled several of them up through the floor but I have not had fenders, hood, motors, transmissions, interiors to deal with so it was a straight forward job...and the torch was great for the mounting bolts.
Now the sawzall might sound good but you could probably fetch a few shiny pennies for a complete column on ebay
Glack
