clutch linkage
Old Mar 21, 2005 | 01:20 PM
blatherskite's Avatar
blatherskite
clutch linkage
Will the clutch linkage (equalizer pivot etc) from a 6-cylinder work on a 302??
What about the engine mounts??
thanks
Old Mar 21, 2005 | 01:32 PM
fordxxx's Avatar
fordxxx
The pivot will work on the 302. You need the pivot bracket that bolts onto the bell housing where as the 6 cyl. has a ball thing on the back of the engine.
Old Mar 22, 2005 | 08:30 AM
talisker's Avatar
talisker
I took the ball thing off my 240 when I converted to a 360 and fabricated a bracket. Worked just fine. As for the mounts, changing a 1969 240 to 1973 360, the engine perches had to be moved but the holes were already there and mounts worked fine.
