300 vs. 302 swap question
Old Mar 20, 2005 | 09:17 PM
thecowboy's Avatar
thecowboy
just wondering what the pros and cons of doing this swap is? if any body knows please let me know. ive got a 1980 F-100 stepside (wood bed) and it would make a great hot rod truck. as much as i love the 300 its not a hot rod truck engine. would yall swap the 300 out or build it up?
thanks,
theccowboy
Old Mar 20, 2005 | 09:54 PM
cdherman's Avatar
cdherman
Whatever you do, DON'T swap a 302 for the 300. If you want a hot rod, then fine, get a big block such as 460 and get it over with. To get performace out of a 302, you need two things -- a light vehicle and high revs. The one you don't have, the other you don't want.
Trucks as "rods" are best with a bone rattling basso profundo sort of rumble that you get best with a BIG eight. Used to be, the distinctive sound of a split 6 six was also associated with old "rods" too. Now of course, done wrong, your exhaust can *sometimes* sound like a ricer a bit. Which is definitely not what most of us want. Done right, the 300 can sound and perform awsomely.
Don't let the profusion of 5.0 performance parts convince you that it is a performance engine. It was a popular engine in a lot of vehicles and in a car, it can really be sweet. In a truck it is a compromise, at best, and a joke if you ever try to tow anything but tin cans. If you think the reason to go 302 is because it is cheap, consider that a 460 might cost you a grand more. Is it really worth the trouble to swap in an inferior engine "just" to have a V8? You'll regret it.
I hope I have slammed this thought enough to dissuade you from doing this.
Old Mar 21, 2005 | 07:41 PM
johnboy427's Avatar
johnboy427
I would say a 302 is a good choice, i have seen an 1992 F-150 SWB run 11s in the 1/4 with a stroked 302 and was still very streetable, you will want to run after market heads and the 347 kit is a plus but this is the kind of the thing any motor would need you most likely won't find any stock motor 460 or 302 that will be a racer all motors need work unless you go find a Cammer or something. 302s are cheap and not hard to find and parts are cheap. The 302 won't require a front spring change due to weight like the 460 would and your brakes will still stop you safely. Have fun
-johnoby
Old Mar 21, 2005 | 08:51 PM
mattri's Avatar
mattri
What tranny are you running? You might end up swapping that as well. If you're looking soley for street performance, stop light to stop light, cruising and a little track time I wouldn't go with either a 300 or a 302. Bolt in a 351w. You're going to need new mounts, harness, linkage, exhaust and plumbing (at least) anyway. The 351w still uses the smallblock bell-housing and mounts and you'll get better stroke than with a 347 kit. It's a little stouter at the mains and just as easy (almost) to pull out of a yard.
Old Mar 21, 2005 | 09:16 PM
95 F150's Avatar
95 F150
Saying the 302 can't tow anything but tin cans is an overstatement, I tow a a boat and camper with my little baby 302 and it does just fine. Contrary to popular belief it gets the job done
Old Mar 21, 2005 | 10:13 PM
cdherman's Avatar
cdherman
Sure, the 302 can produce the HP and torque of a 300. If you gear it right and rev it up, it will work. It will even beat the 300 if you rev it far enough -- and if you want to live at 4k then fine, have it your way. He (the original poster) wants a "hot rod" engine. To me, the 302 is not that. Want a novel rod, then keep the 300 and put some nice stuff on it. Want a V8 -- get something with displacement. 302 is just too small for real trucks, no matter how much you rev it.
Old Mar 22, 2005 | 01:06 AM
200000+F150's Avatar
200000+F150
All good points. Personally, I'd build up the 300 just for shock value to the unintiated, but for a "hot rod", you typically want a motor that is suited to turning some RPMs, and a V8 fits that bill better. I noticed that his truck is an '80, so it's pre-EFI. No harness change, 302 and 351 use the same mounts(at least in that body style). All the other stuff you mentioned, he'd need for either one, so yeah, if swapping to a V8, the 351 would clearly be better than a 302. There's no reason to stroke a 302 to a 347 in a fullsize truck. Instead of buying custom parts to stroke it, just get a 351, and spend the saved money on heads, intake, cam etc... But this is the inline forum, so copy Col. Flashman's six and surprise a few people with it!
Old Mar 22, 2005 | 06:32 AM
Icicle's Avatar
Icicle
Wanna do a lot of work and tow houses up mountains...keep the 6
wanna go fast and Rev high? have cheap available bolt on parts....go 302
want something still bigger? go 351....
I get so tired of hearing somebody, at least once in every engine swap thread bring up just throwing a 385 series motor in it.......thats not the answer for everyone.
and to say 302s arent performance engines? Whatever, tell that to the guys running 10s in 4000 pound mustangs, gimme a break.
460 swaps require front end beefing up on an f150 of that vintage, dana 44s with any decent tire size dont like 460s (or ford 9s for that matter)
My vote for what you want.....302
Old Mar 22, 2005 | 08:29 AM
77300i6's Avatar
77300i6
Preach it brother. I too am sick of seeing the 460 for all your performance needs. Not everone wants a big block.
What I would do is build a 302 or a 351 with some nice go fast goodies, supercharger,
3.73's in a 9" w/ 35 spline axles, trac loc, and a C6 w/ a manual valve body and a 2400 stall torque converter. Then sit back watch ricers and camaros scream with agony.
Old Mar 22, 2005 | 09:47 AM
frty7ford's Avatar
frty7ford
I would build a 351w spend the extra money on the heads, intake and exghaust. that is where you will see the most gains in performance
Old Mar 22, 2005 | 06:23 PM
mattri's Avatar
mattri
disregard this post, sorry.
Old Mar 22, 2005 | 11:54 PM
AlfredB1979's Avatar
AlfredB1979
I would build the 351w as well. Unlike a 460, you can get some revs out of it when necessary. 460 = pulling engine....trying to put the characteristics of a 302 into it, well, one can imagine how much sense that makes.
As for having to swap brakes with a 460 swap, well, the though is nice, but unless a truck with a 460 survives 130mph over and over again, there is no need for bigger brakes. Stock F150 disks will stop said truck doing normal highway speeds whethre equipped with a 300, 302, 460, etc.
Old Mar 23, 2005 | 06:12 PM
old75F-100's Avatar
old75F-100
well to me working on a inline six is so easy i can change the plugs in a couple of minutes if i jump into the engine bay this makes working on the engine fun to me. A V-8 is a different story not much room at all if compared to the 300. If you want to hotrod a truck a V-8 would be nice if you want to make the V-8 sound or just have the power to move quickly a built six would provide some jaw dropping power to people that would laugh at a six.
Old Mar 23, 2005 | 07:35 PM
puggies v8's Avatar
puggies v8
Now were talkin! I love 302s! I have a 347 stroker in a 87 stang! But I would keep the 300! If the V8 is a must! go to a 351w or better a 460mid to early 70s with c6! The 347 is a great engine! 347$$$,,300$
Old Mar 23, 2005 | 10:57 PM
andym's Avatar
andym
It depends on what you want to do with the truck, what you expect from it, and what your budget is. If there's no budget, then we can have some fun.
