oil additives
Old Mar 20, 2005 | 03:02 PM
butch a 250 d's Avatar
butch a 250 d
oil additives
is anybody out there running any kind of additives
started my truck up yesterday and just for a second it sounded like a stuck valve or maybe carbon under the valve seat only did it the once
thanks butch
Old Mar 20, 2005 | 07:05 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Just run a good oil that is diesel rated.
With todays oil addative package that is already in the oil, anything you add may mess up something else in the addative package.
Old Mar 20, 2005 | 07:25 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
In all my vehicles I just use the CI-4 oil and change it in the 93 every 3000 miles. It has 198000 and no problems. Just use oil, as stated by Dave S. you might mess up in the standard additives pkg. you might want to try an additive in the fuel.
Old Mar 20, 2005 | 07:27 PM
butch a 250 d
i use 15/40 from petro can or cheveron or esso change every 3000 mile
eng uses about 2 litters between changes
thanks butch
Old Mar 20, 2005 | 07:33 PM
bigredtruckmi
Veteran: Navy
doesn't sound too bad just keep what you are doing and try a fuel additive this might clear out any carbon buildup and clean your injectors. How many miles on these injectors?
Old Mar 21, 2005 | 12:11 AM
butch a 250 d
that is unkown got no info when i bought the truck
ill be login off for about a month now
butch
Old Apr 5, 2005 | 08:51 PM
cobarjet's Avatar
cobarjet
I use a qt of lucas with the 15 40 northland oil i use
