Offroad & 4x4
Need a LiL Help
Old Mar 20, 2005 | 01:24 PM
ramboss429's Avatar
ramboss429
Need a LiL Help
Hey guys this is probably gonna sound retarted......I just ran into the toughest problem so far converting my '67 to 4x4. I got the front axle all mounted up last night (Thanks to Ivan an Pro's helpful galleries), and now I tore it back out. I need to replace the bushings in my leaf springs with my new poly ones. How the Hell does a guy get the old crappy, rubber bushings outta there? Someone have a trick or tip? If not, they're getting tossed into a fire.....
Old Mar 20, 2005 | 01:34 PM
'88_F-150's Avatar
'88_F-150
burn em out with a torch
Old Mar 20, 2005 | 02:03 PM
jesse460's Avatar
jesse460
Then clean the eye out with a wire wheel in your drill.
Old Mar 20, 2005 | 02:43 PM
bremen242's Avatar
bremen242
This is my method-
get a mapp gas torch.
heat the inside of the bushing (the metal part) until it is smoking hot.
the inside of bushing will now push out with something hard (old bolt/rebar whatever)
scrape the flaming rubber out
quench the metal sleeve inside still in the spring with wd 40 (be careful not to hit the hot spring)
pound out the bushing with a chisel or air chisel. If you have an air chisel, you can just slice it out.
Or, pay you buddy $30 bux to burn them out with an oxy torch.
those new poly bushings are a breeze to install. pound both sides in with a hammer, lube the inside of the bushing with the supplied lube, and pound the metal bushing into the poly part.
the OEM rubber/metal ones require a big press.
Old Mar 20, 2005 | 03:21 PM
proeliator's Avatar
proeliator
They guys totally covered it. I just wanted to add....never throw your springs into a fire to burn the bushings out (maybe you were kidding, but I've heard of it being done). Tempered steel doesn't take kindly to that.
Old Mar 20, 2005 | 03:44 PM
monsterbaby's Avatar
monsterbaby
just to add to Pro's comment also don't use the oxy/torch on the metal of the spring really not a good Idea, I have tried drilling rubber out, adn burning it out, and lately have taken to just using my press to prss them out, but without a press burning them out is the best just don't apply the heat to the spring itself.
Old Mar 20, 2005 | 04:38 PM
mustange70's Avatar
mustange70
Yeah you should be able to pick up a cheap press for upr bench top for like 30-40 bucks, then you will have a press whenever you need it, and it will pay for itself within a couple of uses.
My dad has just a simple one (just a cheap one, my grandpa has a 60 ton hydraulic one if we ever need to use it), and its paid for itself 10 times over it seems.
Old Mar 20, 2005 | 09:01 PM
ramboss429's Avatar
ramboss429
Thanks for all the info guys, I was planning on using my torch, but didn't know if it was the right way to do it. I might hafta post up some pics of my progress.....
