granite tile
Old Mar 20, 2005 | 12:17 PM
alfama351's Avatar
alfama351
granite tile
I've done a lot a ceramic tile installations, both floor and walls, but I've never done granite, the wife picked out granite, and because I never done it before, I'm a little apprehensive to say the least, I know that with granite there's no room for mistake like ceramic, so with that said, if anyone out there as any pointers or advice, it would really be appreciated.
Thanks. Alfredo
Old Mar 20, 2005 | 03:40 PM
chuck641's Avatar
chuck641
If you have a good diamond blade tile saw you wont have anything to worry about besides the usual that you would with ceramic.
I actually like laying granite better than ceramic because you normally have very small grout lines with granite and in my opinion its easier to keep everything straight, with that being said there is less room to 'fudge' in any error from the room or cabinets or whatever else being out of square.
like anything though take your time and itll look great
Jason
Old Mar 21, 2005 | 01:02 PM
alfama351's Avatar
alfama351
thanks
Hey Jason, thanks for the reply, I'm just a little apprehensive, because it is my first time working with granite, I'm going to use thinset, is that appropriate?
Old Mar 21, 2005 | 05:41 PM
ColtM4's Avatar
ColtM4
If you are laying 12x12 make sure your floor is perfectly flat and you will save yourself lots of time. Big tiles get off kilter when your floor isn't flat. Spread thinset evenly, but you really need to make sure you have complete adhesion or else tile will break. So install and remove to make sure all of the tile is covered with thinset. Often you will need to butter the back of the tile with a thin layer to make sure you get complete adhesion on less than flat floors.
Old Mar 21, 2005 | 06:24 PM
chevyman22's Avatar
chevyman22
If your floor is out of whack a little bit just use a larger notch trowel. Like said before, use a nice diamond blade saw and it cuts fine.
tseekins
23
Jun 9, 2013 08:17 PM
kpwall
Dec 14, 2006 04:52 PM
fred_79f250
17
Oct 23, 2006 12:00 PM
The Fife
16
May 23, 2004 04:48 PM
big_daddy_velvet
18
Oct 11, 2003 11:44 AM
