four wheel drive emblems
Old Mar 20, 2005 | 10:42 AM
mr big's Avatar
mr big
Angry four wheel drive emblems
just bought a 1965 f100 4x4 and want to restore it back to original looking condition. emblems have been removed any suggestions.
Old Mar 20, 2005 | 10:44 AM
mr big's Avatar
mr big
just bought a 1965 f100 4x4 and need body emblems where is a good place to look?
Old Mar 20, 2005 | 01:00 PM
65-f100's Avatar
65-f100
I have had good luck with LMC Truck. 1-800 LMC-Truck
If you don't have a catalog you can order one. Unfortunately they don't list parts on their web site.
Old Mar 20, 2005 | 01:03 PM
65-f100's Avatar
65-f100
I have good luck with LMC Truck.
1-800-LMC-TRUCK. You have to order a catalog, they do not list parts on the web site.
I have one here if you need part numbers or something.
Old Mar 20, 2005 | 01:07 PM
barry's Avatar
barry
Which emblems exactly are you looking for? For 65, they show the "Ford F-100" emblem and a moulding on the hood, plus the long body mouldings. For 66 they show "Ford F-100 4Wheel Drive" . Also same body mouldings. Post your VIN and what you need and I can run a search for you.
Barry
Old Mar 20, 2005 | 01:17 PM
barry's Avatar
barry
I did a quick search for the "Ford F-100" Emblem and found some NOS ones.
C5TZ 16720-B 2 required
Green Sales, Cinci, Oh. 1-800-543-4959 qty 3
Wesley Obs., Liberty, Ky 1-606-787-5293 qty 2
The "Ford F-100 4 wheel drive ones",( 66 trucks only) I found some also
C6TZ 16720-A 2 req.
Dennis Carpenter Charlotte, NC 1-800-476-9653 qty 37 (repo)
Melvin's Classics, Conyers, GA 1-770-761-6800 qty 1
I can search for other parts also if you need anything. Always glad to help.
Barry
Old Mar 20, 2005 | 02:42 PM
mr big's Avatar
mr big
1965 four wheel drive emblem
the vin# for this truck is f26de613689 which leads me to believe that it is an f250 not an f100 as the seller described. the truck will be delivered to me on tuesday all i can hope is that it is as i thought it was described.
Old Mar 20, 2005 | 03:05 PM
barry's Avatar
barry
Yes, it's a F-250. The "F26 is a dead giveaway. Your Vin breaks down as follows.
F26DE613689
F26= F-250 4x4
D= 352 2v engine
E= Mahwah, NJ assembly plant
613689= 1965 year
According to my parts books the side emblems on the fender should say " Ford F-250" , no 4x4 emblems.
Ok, none showed up on the locator, but that doesn't mean that's there isn't any out there in NOS or used. Get the truck home and see what's missing and make sure it's a F-250 or something cobbled together. You may want to check the frame just in front of the cab mounts to see if the serial number matches what you have now.
Barry
Old Mar 21, 2005 | 10:49 AM
phatz's Avatar
phatz
Smile 4x4 emblems
Let me know if you are interested in Used ORIGINALS Ihave a few. Phatz
Old Mar 21, 2005 | 02:58 PM
mr big's Avatar
mr big
depending on their condition i might be interested
Old Mar 21, 2005 | 03:00 PM
mr big's Avatar
mr big
thought so 8 lug dead give away. i will check the frame when it shows up should be tomorrow night thanks for the info.
Old Mar 21, 2005 | 03:28 PM
garbz2's Avatar
garbz2
The Four Wheel Drive inserts are made by D. so he should have them. LMC and allt eh others buy his stuff for resale.
Garbz
Old Mar 21, 2005 | 04:11 PM
mr big's Avatar
mr big
my ford book says that in 1965 the fender emblems do say four wheel drive does anyone know if this is true? i just want to make this truck as original as possible. gary
Old Mar 21, 2005 | 04:34 PM
barry's Avatar
barry
Where are you? I'm in Newington, right by Hartford. What parts book do you have? THe 64-72 series is the last set they issued to us. The single year ones are not as reliable. They may have started with the emblems in 65, but it had to be near the end of the model year, if at all. I sent you a PM on the warranty plate info.
Barry
Old Mar 21, 2005 | 05:18 PM
tomsrod's Avatar
tomsrod
In 1965, both the F100 and F250 4x4s had red inserts that said "100" and "250" respectively. In 1966, the F100 4x4's inserts said "four wheel drive" and the F250s said "250". The chrome emblems in 1965 and the 1966 F250 looked similar to the 1963 and 1964 emblems, but differed by having two mounting studs on the top and one on the bottom. The chrome emblems for the 1966 F100 4x4s was the same as the one that held the red "Twin-I-Beam", "Ranger" or "Camper Special" inserts. At least thats the way I remember it.
