Ok to run engine for short while?
Old Mar 20, 2005 | 09:43 AM
bigtexan99's Avatar
bigtexan99
Hi, I have a 5.4 2004 Screw. I happen to live very close to work, and grocery shopping. Sometimes, the engine temp does not climb to "normal", ie, the trip is only 2 miles and the engine is still 'cold'.
Is there any damage that might occur from this? It seems like I heard on older cars that if you did not let them get up to normal operating temperature that you would have some sort of 'buildup' or failure of plugs or such.
Thanks!
Old Mar 20, 2005 | 10:40 AM
bigdavewilson's Avatar
bigdavewilson
Lots of short trips
Thanks!
Make sure you follow the Severe Service oil change interval. Your exhaust system may not last as long as it would if it got warmer and evaporated the condensation. Otherwise you should be OK.
Old Mar 20, 2005 | 11:27 AM
tomdoggie's Avatar
tomdoggie
What can you do. Move closer or walk to work. Good luck. No serious damage will result.
Old Mar 20, 2005 | 11:33 AM
Flash's Avatar
Flash
In the long term, yes you can be doing damage to the engine. You are the type of driver that the manufacturers hate. When you start the engine, it will start condensing moisture build up inside the engine. The oil has to hydrolize this water and when the engine reachs it normal operating temperature, the water is cooked off. Your engine is not getting this "cook off". Your engine is going to have a lot of sludge build up. Might want to take a look at the oil filler cap and see if you have any brown foamy looking stuff on it. If so, the sludge build up has started. You may have to go for a ride every week to cook off the moisture or you may want to change oil every 2000 miles. In your case, I would suggest a synthetic. Might want to find some Mobil 7500 in 5w-20 and change it often when the engine is hot.
Old Mar 20, 2005 | 11:51 AM
Ruckus's Avatar
Ruckus
Smile
No problem at all in my opinion.Years ago the exhaust systems would rot out due to excessive condensation when driven under your type of conditions.However, with the stainless steel exhaust systems that are used today, no problem.I would suggest an occaisional 15-20 mile drive and change the oil every 4-6 months.Good Luck!
Old Mar 20, 2005 | 03:07 PM
bigtexan99's Avatar
bigtexan99
Thanks for the tips. I do drive it alot more on the weekends, its just mon -fri that it hardly gets used. If the weather is nice I ride my trusty old Honda Rebel 250 into the office.
Steve
Old Mar 20, 2005 | 06:01 PM
Ford-man22's Avatar
Ford-man22
Since you don't live far from where you need to go, drive it hard. It's made to warm itself. Like when you first start it, in the morning, it holds the shifts longer to build up heat. It's in the owners book for more detail.
Old Mar 21, 2005 | 10:39 AM
KevinM's Avatar
KevinM
Don't drive a cold engine hard!
Old Mar 21, 2005 | 11:58 AM
Ruckus's Avatar
Ruckus
Smile
Do not rev a cold engine and I see some people rev their engine before shutting off.Don't do it.It just wears the engine and is totally unnecessary.They cost to much!Save your revving for when passing a Chevy or Dodge.Then give it heck!!!!!I mean blow their doors off!!!!!!!!!! Good Luck!
Old Mar 22, 2005 | 05:54 AM
lardman's Avatar
lardman
When I was in high school, the kid across the street had an old Aspen Wagon . Every morning in the winter he would start the car and redline the engine to warm it up so he could defrost his windows. Needless to say, the engine didn't last long.
Old Mar 22, 2005 | 10:32 PM
Ford-man22's Avatar
Ford-man22
I don't mean stomp it. Just get it up to about 3 grand. EVERY ford I have ever owned ( before this one) has been a 5 speed and I have always shifted them at 3 grand. One motor, my old 2.3 in my 90 model, had over 200,000 WHEN I SOLD IT. The only problem I ever had with it was a broken valve spring when I tried to race a buddy of mine with a 318 powered dodge. It had 160,000 when that happened.
Old Mar 23, 2005 | 03:01 PM
BlueFX4Flare's Avatar
BlueFX4Flare
I have the same problem. I also live very close to work. I usually carry both sets of keys, drive to a coffee shop, lock the truck while it's still idling and then get back in and go to work. It usually gets to normal temp by the time I am at work.
Sometimes I take a longer route to work.
Lately in the winter with the truck plugged in, it warms up half way to work.
And when the weather warms up I will ride in to work as well, on a 99 ZX-6R Ninja.
Old Mar 24, 2005 | 08:44 AM
KevinM's Avatar
KevinM
I wouldn't even take it to 3 grand.
Old Mar 24, 2005 | 08:56 AM
Ruckus's Avatar
Ruckus
I watched my tach (5.4) yesterday at start up when cold parked in the garage.It started at 1200 and settled down to around 650 idle in park.All I know is there would be no need for me to rev my engine unless I just wanted to hear my new exhaust system.Good Luck!
