1978 - 1996 Big Bronco
Getting old shocks off
Old Mar 20, 2005 | 09:10 AM
tombob's Avatar
tombob
I have an 1980 Bronco and I need to repalce the shocks. The shocks on the machine arre not original, but it looks as if they have been on there a LONG time; they are rusted and several are oozing oil.
I really don't want to pay the local wrench jockeys $15-$20 per shock to install the new shocks. I want to do it myself if the grief factor isn't too bad.
My concern is the front quad shocks. While I am not worried about cracking loose the bottom nuts, what about the top? Doesn't look as though there is a lot of room to get good leverage and I don't own a cutting torch to cut them off. Any suggestions for making the job any easier?
I assume I could douse the nuts and threas with penetrating oil for a week or so before I attempt the job?
Thanks guys!
Old Mar 20, 2005 | 10:49 AM
gjordan456's Avatar
gjordan456
that's your best bet tombob, douse everything with a good penetrating spray a couple times, the stuff really works great, I've used Marvel super spray and PB blaster and they both work great, I did my truck shocks awhile back w/ quad's on front and they came off pretty easy...
Old Mar 20, 2005 | 01:12 PM
jacque_strap's Avatar
jacque_strap
Mine were like yours. I either twisted until the top bolt broke or you can just cut the shock on the underside of the tower. (Don't cut into the hydraulic part, cut through the bushing and you will be cutting throught the bolt at the same time.) Hope that made sense.
Old Mar 20, 2005 | 10:24 PM
littleneddy's Avatar
littleneddy
I replaced mine a few weeks ago... was able to put a box end on the lower nut and was able to "feel" my way with a socket on the top nut.
For me the bigger problem was braking loose the the nut and bolt on the bottom of the shock.
Old Mar 22, 2005 | 03:43 PM
Katmandu's Avatar
Katmandu
Question
I really don't want to pay the local wrench jockeys $15-$20 per shock to install the new shocks. I want to do it myself if the grief factor isn't too bad. Thanks guys!
What's the correct way to support the vehicle when changing shocks ??
Should the shocks be extended or compressed for easiest installation ??
Old Mar 22, 2005 | 04:38 PM
iagainsti's Avatar
iagainsti
I had to compress mine and then ziptie them so they wouldnt reopen. I still have the bruises on my chest 3 wks later. Just cut the ziptie when you have them inplace.
Old Mar 23, 2005 | 11:04 PM
littleneddy
I used a jack stand.
I'm with iagainsti... the shocks came with nylon ties compressing them. I bolted in the bottoms, aligned the tops and cut the straps. With one or two I misaligned them and had to compress them and man handle them into place.
Dcope17
Jul 15, 2016 08:09 PM
bf5113x
Jul 8, 2016 02:11 PM
niveknonrev
May 22, 2015 08:31 PM
b2trausch
Oct 23, 2007 08:36 AM
fujio001
2004 - 2008 F150
Jan 21, 2005 12:19 PM
