Need new shocks... Advice
Old Jul 12, 2016 | 10:38 AM
Dcope17's Avatar
Dcope17
Stock 2001 4WD EX... Tow my jeep on a trailer mostly with it ( about 6k pounds total )
Needing some new shocks. I don't want generic shocks that say they are for the EX simply because they fit. I want shocks that are properly valved fo the Ex's weight. Not looking to spend $100 a shock, want something economical ( since I drive the truck about once a month ) but don't want crap either.
Anyway, what have you bought that you liked?
Thanks FTE.
Dan
Old Jul 12, 2016 | 10:51 AM
mecdac's Avatar
mecdac
Bilstein 5100
Old Jul 12, 2016 | 11:08 AM
StreamOn's Avatar
StreamOn
I second the Bilstein 5100,
Old Jul 12, 2016 | 11:13 AM
74Mav's Avatar
74Mav
Since I'm on a tight budget, and my Ex has a dual shock kit on the front, I opted for SkyJacker Nitro 8000 Softride shocks. They should be here on Thursday, and installed this coming weekend.
However, I've read the Bilstein 5100 and Rancho RS9000 are better shocks. But, a ballpoint pen spring would probably be better than what's on my Ex right now...
Old Jul 12, 2016 | 01:00 PM
wizkid00104's Avatar
wizkid00104
I am very pleased with my Monroe Gas Magnums. Nothing fancy but the smoothed the ride out in F250 at the recommendation of a friend. Part #'s 34686 and 34687. With a rebate from Monroe and discounts from Advance Auto, I replaced all 4 for about $100 back in 2014.
Old Jul 12, 2016 | 01:04 PM
pirate4x4_camo's Avatar
pirate4x4_camo
While weight is a factor, shocks are valved to desired ride chartaristics like ride quality and handeling. Other then towing, what sort of ride are looking for ?
Old Jul 12, 2016 | 01:11 PM
Matt M, PA's Avatar
Matt M, PA
I bought the OEM shocks form the dealer. I'm well pleased with them.
When I realized that Ford sells a different shock for the front depending on gas or diesel...but the aftermarket companies don't...the choice was obvious...
Old Jul 12, 2016 | 02:46 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I will chime in for the Bilsteins. Have them on mine, and they are WORLDS better than the Monroe's I had on before.
Old Jul 12, 2016 | 03:20 PM
Magnus E's Avatar
Magnus E
For a stock height Ex (like mine) the Bilstein 4600 is a good choice. They are yellow and blue vs. Silver and black that you get with Bilstein 5100 (for lifted trucks). According to the internets the 4600 and 5100 are virtually the same with the 4600 designed for stock and 5100 for lifted. Valving is the same.
Old Jul 12, 2016 | 05:20 PM
LivingLarge's Avatar
LivingLarge
This^^^^^^^^^^^
I also had the Rancho's, but my 5100's in my opinion were a much better feel.
Old Jul 12, 2016 | 05:36 PM
Dcope17's Avatar
Dcope17
I'm looking for ( I guess ) a factory type ride.
I guess if I had to choose, I like things barely on the firm side.
Old Jul 12, 2016 | 05:51 PM
pirate4x4_camo
I'd suggest you go to rockauto.com and look up shocks they have them broken down into catagories, that will give you an idea of where to start
Factory ride
Improved handeling
Heavy duty
Load assist
ECT
. You can research from there but keep in mind ride quality is fairly subjective so my idea of soft may your ideal shock. It's rather maddening actually.
Old Jul 13, 2016 | 08:33 PM
DOOM173's Avatar
DOOM173
Would there be an issue using the 5100's on a stock height Excursion V-10?
Old Jul 13, 2016 | 10:03 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Yes. You need the 4600s for stock height. The 5100s are too long...especially in the rear. If you bottom out a 5100 on a stock height truck, you will have a catastrophic failure of the shock.
Old Jul 14, 2016 | 05:00 PM
DOOM173's Avatar
DOOM173
Thank you very much for the reply sir.
I'll be getting the 4600's.
