pcv/brake booster
Old Mar 19, 2005 | 07:34 PM
'70_f-100's Avatar
'70_f-100
pcv/brake booster
ijust learned the hard way obut how the pcv system works, and i was wondering what the effects of routing the pcv hose into a "T" w/my power brake booster vacuum and the into my carb. plate.
by doing that are my brakes still going 2 function properly?
also will my pcv system function properly?
1970 f-100 custom w/390 FE, 2bbl motorcraft model 2100
C-6 tranny
Old Mar 19, 2005 | 08:43 PM
jor's Avatar
jor
I tried to do that with my 67 after I put a new carb on it. The new carb didn't have the vacuum port - bad idea. The brake cannister requires a dedicated vacuum source. If you do the "T," stopping at red lights becomes a real adventure. Good luck and let us know what you figure out.
jor
Old Mar 19, 2005 | 08:55 PM
'70_f-100's Avatar
'70_f-100
thx for the warning i'll let u know what i figure out.
untill then i'm off to the parts store!
Old Mar 20, 2005 | 08:31 AM
orich's Avatar
orich
I only will say, If ford thought it was the way to go, they would have done it.
my 2cents
orich
