Replacing ignition wire 5.0
Old Mar 19, 2005 | 07:27 PM
hop's Avatar
hop
Is it necessary to remove the throttle body to replace the last plug wire on the passenger side? This one looks to be a bugger.
Purchased wires from Carquest and they appear to be 2-3 in. longer. Is this typical on replacement wiring? They are for cast iron manifold and I have forgot on how to identify which that I have but the set of wires for a tubular manifold didnot have the shields that this set has and that my originals do have.
2000XLT 5.0 2wd 88k mi
Old Mar 19, 2005 | 11:55 PM
CobraXP's Avatar
CobraXP
Easiest way to change the wires is through the fenderwells. If you take the tire off, there is a flap in the fenderwell you can remove. It is just held in with push pins. Take that down, and you are stairing at the plugs...
