exhaust
Old Mar 19, 2005 | 01:53 PM
7.3whitemonsta's Avatar
7.3whitemonsta
exhaust
can i just cut out the cat and muffler to have straight pipe with the stock size or is it pointless?
Old Mar 19, 2005 | 02:51 PM
QFD90's Avatar
QFD90
Do a search in this site about straight pipes. You will find lots of info. from guys that have done just what you are wanting to do.
Old Mar 19, 2005 | 05:12 PM
Texascadillac42's Avatar
Texascadillac42
There is definitely a point to it. If your motor is stock, and doesnt have any chips or tuners installed, then the stock diameter exhaust will be plenty. Removing the cat and muffler will make the truck rev up quicker, especially in the higher revs. It is a relatively straightforward job, and lets the turbo whistle more, which is always a good thing in my opinion
Old Mar 19, 2005 | 06:21 PM
444dieselrod's Avatar
444dieselrod
The cat is a HUGE restriction in the exhaust. not only will it allow the truck to rev like a gasser when punched, it will also reduce your EGT's significantly, and with the removed muffler it will give a real deep tone to the truck, but there will be a litttle flutter sound from the turbo.
If you are in there I do suggest going to 4" pipe. the stock 3" is fine, and I have put it on a few PSD, I went with the huge pipes on mine because they realy help kill the exhaust flutter, added a really deep tone to the truck, and it realy whistles at idle now. but it realy comes down to a cost issue, 3" VS 4" the larger the pipe, the deeper the tone, and the better the flow.
Diesel Rod
Old Mar 20, 2005 | 01:12 AM
Frost13's Avatar
Frost13
straightpipe it. it should help performance and lower your egt's. but most importantly of all, it will help the sound.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
