3/4 ton E-250
Old Mar 19, 2005 | 08:50 AM
Heavy460's Avatar
Heavy460
3/4 ton E-250
I looked for a van forum.Did not see one.Hear is my problem.I have a 1989 E-250 3/4 ton van that cuts out while running on a cold start.It will start wright back up,but i have to keep my foot on the gas just a little.If i let off the gas pedal it will cut out a few times then just stall.Even if i keep my foot on the gas i can hear a slight cut out of power.Last time i drove it was Superbowl sunday,and on the way to my dads house it stalled on me.I stoped and put it into park.When i went to restart the motor it just barely started,and the head lights flickerd very lightly.I had to keep my foot down on the gas all the way to my dads house,because it was going to stall.After the superbowl was over i go out to start it and it ran fine all the way home.Then two days later i goto start it and it starts all over again with the motor cutting out then it just stalls.I put my hands up and say thats it i dont have the time and money to mess with it wright now.Its ben sitting since then and has not ben started untill yesterday.It started up fine and no cutting out or stalling.I didnt drive it because id get stuck in my driveway with all the snow.Help!
Old Mar 19, 2005 | 09:47 AM
tex94F250's Avatar
tex94F250
Van forum is just below the Bronco forum. Sounds like an internal voltage regulator/alternator issue, maybe. Check charging system/battery. Next guess is fuel pressure regulator/fuel filter, just don't know van systems though.
