front axle help please
Old Jan 30, 2001 | 06:52 AM
DannyP's Avatar
DannyP
Old Apr 26, 2001 | 05:34 PM
cpnhgnjnky's Avatar
cpnhgnjnky
could some one please tell me the best way to install the front axle seal (passenger) on my 95 F150 4x4? i would greatly appreciate it!
cpnhgnjnky
Old Apr 26, 2001 | 11:06 PM
PAUL_2's Avatar
PAUL_2
Youll have to remove the axle shaft , Its a fairly involved job that requires you to remove the spindle in order to remove the axle shaft . Ive done the left side before & its a little easier because its just a short one piece shaft , the right side is a little harder because of the two piece axle . Just make sure you thoroughly clean the spindle bolts & nuts before you reinstall them , they are fine thread & easily stripped if there is any dirt on them . Make sure you torque them to the proper specs too .
