Sponsored by: Real Truck
Too much driveshaft play
Old Mar 18, 2005 | 08:55 PM
high ho silver's Avatar
high ho silver
Unhappy Too much driveshaft play
OK all this talk about vibration and driveshaft angle got me looking at my own vibration problem. I have a 2000 ex cab with short bed. (So it doesn't have a center carrier bearing). Was underneath checking for bad u-joint or missing weights. So I put truck in neutral, blocked the tires, and crawled underneath. All I found was some play in the transfer case end of the rear driveshaft. Is this normal anyone? There was about .030-.050 play up and down and about .025 front to back. My thoughts are tailshaft bearing worn. What yall think?
Old Mar 19, 2005 | 04:16 PM
high ho silver
If anyone happens to be lurking around under their truck one day, could you check this on your truck? I don't want to start tearing something apart if it doesn't need it.
Thanks!
