distributor problem
Old Mar 18, 2005 | 07:05 PM
fordnut99's Avatar
fordnut99
Question distributor problem
86 ford ignition system,when u hold out of motor,all hooked up,it acts like a possitive.when u touch to block it sparks ,the hole external part of distributor shorts i have changed it a few times and the brain,electrical wires can some one tell me why and what i can do to fix it
Old Mar 18, 2005 | 10:09 PM
Franklin2's Avatar
Franklin2
What engine? Do you have a vacuum advance(vacuum line to distributor?)
What are you holding? Sparkplug wire? Coil wire? Some of other wire(what color?)
Explain what this means. What are you seeing?
You have changed the complete distributor or just a module? Or both? Where is the "brain" located on your truck?
