a/c cycles too often
Old Apr 29, 2001 | 12:39 PM
Franklin2's Avatar
Franklin2
Old Apr 29, 2001 | 02:41 PM
stevieray's Avatar
stevieray
My a/c seems to cycle too often when the controls are set for heat and screen/floor/mid. It cycles on and off every couple of minutes even on a warm day with low humidity. When set in the a/c setting it works just fine. It didn't do this during the winter but now that it has warmed up it is doing it. It was doing this when I bought the truck and when turning a corner the truck would stall! I bought the truck any way and cleaned the idle valve and solved the stalling problems but then it got cold so it stopped cycling untill 2 weeks ago. any ideas?
Old Apr 29, 2001 | 10:58 PM
PAUL_2's Avatar
PAUL_2
Assuming the system has a proper charge & no leaks then the next likely cause would be the clutch cycling switch , its screws into a shrader valve on the accumulator . First check for leaks & that the system is fully charged .
