Engine swap ?
Old Apr 29, 2001 | 05:22 PM
davidz's Avatar
davidz
Engine swap ?
I have a perfectly good 88 F-250 with a shot 351W. I have a
great running 302 in a shot 84 Lincoln. Can I put the 302 in the F-250? I entend to haul no more than a 12ft jon boat in back. Thank you for any responce.
Old Apr 29, 2001 | 06:25 PM
fatforty's Avatar
fatforty
Engine swap ?
Hi, welcome to the boards. Your 302 will fit right in the only problem you will run into is with the computer, and maybe the location of the fuel injection. The lincoln computer might change right over but I don't know. You could have to relocate the air box depending on where it is in the lincoln. This swap is very doable. might be easier to find a junker with a 302 and get the injection and computer. John
Old Apr 29, 2001 | 06:51 PM
davidz's Avatar
davidz
Engine swap ?
Thanks so much for the reply. Am thinking going carb. No computer. This truck is for me and my 8yr old's fishing.
Possible?
Old Apr 29, 2001 | 07:39 PM
fatforty's Avatar
fatforty
Engine swap ?
Hi, I don't know what is involved if you can use the pump in the tank or not but a carb would make it a whole lot simpler. John
Old Apr 29, 2001 | 07:45 PM
billyb's Avatar
billyb
Engine swap ?
save yourself a lot of headaches and sell the 302, rebuild the 351 with the proceeds from the 302 helping to pay for it.
most swappers are going from smaller to larger. success leaves clues!
Old Apr 29, 2001 | 07:55 PM
davidz's Avatar
davidz
Engine swap ?
[font size="1" color="#FF0000"]LAST EDITED ON 29-Apr-01 AT 08:58 PM (EST)[/font][p]Would like to thank all of you for the replys!
So far it's a go!
Old Apr 29, 2001 | 08:06 PM
Franklin2's Avatar
Franklin2
Engine swap ?
After all the work and headaches of switching it all over, I believe you are going to be disappointed with the 302 and also de-value your truck.
Old Apr 29, 2001 | 08:14 PM
Pastmaster's Avatar
Pastmaster
Engine swap ?
IT should swap in fine. Since all your hauling is a small boat, the 302 should supply adequate power, it will be no speed demon, but good enough. I think 84 lincoln 302s had the CFI fuel injectin, which I would say dump for a 4 barrel carb. That would be a better idea. The CFI was crap.
Old Apr 29, 2001 | 08:39 PM
davidz's Avatar
davidz
Engine swap ?
Pastmaster,
I agree with the carb. How about the computer? Can I do away with it? I have freinds that say yes.
Thanks to you and all that reply. This is a GREAT forum!
Old Apr 30, 2001 | 09:38 AM
Pastmaster's Avatar
Pastmaster
Engine swap ?
yep, lucky for you, there were no computer controlled tranmissions then and really no other functions. I say you might want to keep it in the truck, but just not used. You never know when it may become handy again.
Old Apr 30, 2001 | 11:16 AM
loudfords's Avatar
loudfords
Engine swap ?
psu927
1978 - 1996 Big Bronco
Aug 8, 2007 05:40 PM
JaybirdT
Jun 21, 2007 06:48 AM
kssouth
Engine Swaps
Jun 15, 2007 04:08 PM
psu927
Oct 16, 2006 07:07 AM
padd
Jan 28, 2005 10:10 PM
