cylinder heads
Old Mar 18, 2005 | 02:37 PM
dartcc's Avatar
dartcc
cylinder heads
does anyone know where to find the cyl head cc for a 93 460
thanks
Justin
Old Mar 22, 2005 | 11:30 PM
airharley's Avatar
airharley
You can use the casting code off of your head and call the dealership to find a specific. But let's get more to the point here. What is the purpose of the info? Are you trying to improve your engine or just figure out compression ratio? I am not by any means trying to sound snotty about it just curious. You can use a conservative 92cc for each chamber to start with. But remember the chamber volume is affected buy how the heads were finish machined.
Old Mar 23, 2005 | 08:04 PM
The "Mad Porter"'s Avatar
The "Mad Porter"
Talking Link to RHP website with cylinder head casting numbers and information.
thanks
Justin
The E7 and F3 fuelies have chambers very similar to the D3VE passenger car castings. The E7 is exactly the same and the F3 is a bit tighter around the exhaust valve. The are approximately 95 to 96 CC's undecked.
Regards,
SMJ/RHP
http://reincarnation-automotive.com
