cam lift
Old Mar 21, 2005 | 03:17 PM
brennamp's Avatar
brennamp
cam lift
I have a 79 460, stock, I was wondering how much lift the stock valve springs will hold?
Mike
Old Mar 22, 2005 | 10:18 AM
wizzard351's Avatar
wizzard351
its always a good idea to change springs when doin a cam swap cuzz the ol'stockers will lose preshure with age but if ya stay under a .500 lift ya shuold be ok you also change the springs with out takin of the heads if ya have acses to an air compreser just take out the plugs and run the air line into the head and change the springs
Old Mar 23, 2005 | 08:12 PM
The "Mad Porter"'s Avatar
The "Mad Porter"
Talking The problem is not the springs even though they are garbage...
Mike
The issue lies with retainer to seal/guide clearance. Once you get to about .530" lift you can run into retainer seal contact.
That being said the stock springs are barely adequat for a stock cam. Replace the springs with matching units from the cam manufacturer. The extended RPM range of a different cam will require better springs for good valve train control.
As a side note you can change springs with nothing more than the cylinder you are working on at TDC. The valves will not drop down into the cylinder. You can easily change springs and seals to accomodate more lift.
Regards,
SMJ/RHP
http://reincarnation-automotive.com
Lmnop156
Nov 26, 2013 02:23 PM
usmc00
Aug 18, 2013 03:38 AM
kdokey
1997 - 2003 F150
Aug 5, 2010 12:10 PM
mdjohnson
Jan 27, 2006 11:19 PM
volcomestone
1983 - 2012 Ranger & B-Series
39
Dec 8, 2003 11:02 PM
