6.9--7.3 heads
Old Mar 18, 2005 | 08:47 AM
diesel-weasel's Avatar
diesel-weasel
Question 6.9--7.3 heads
other than head bolt size,is there any different in these heads can 6.9 heads be installed on a 7.3 block if the bolt holes are enlarged ?
Old Mar 18, 2005 | 09:42 AM
Spectramac's Avatar
Spectramac
Nope, we tried that about 6 months ago.
With enough work, you might get them on there, but they would probably leak water all over the place. The 6.9s have extra water passages in the lower corners and on the intake side. The 7.3s have these all plugged. Then there's the different length head bolts near the exhaust. The 6.9 head gaskets had a fix for the lower corner leaks, but the 7.3 gaskets that I've seen don't have it.
