rear main/ no engine out
Old May 3, 2001 | 10:55 AM
chugdog's Avatar
chugdog
hey guys ive got a 85 100 4x4 with a 460 and i need to know if i can do the rear main seal without pulling the motor out.One mate says i can jack the chassis to give the front diff full travel then undo the sump bolts and slide the sump out backwards.the only problem is that ive only got about 2-3cms between the sump and the chassis brace(above the diff)i just read that you can remove the factory rivets and replace them with a suitable sized nut & bolt is this what i need to do??to give me the clearance i need to slide the sump out backwards.if anyone has done this job (im sure someone has)without removing the motor PLEASE reply cos im dreading pulling the motor out.
Old May 3, 2001 | 04:26 PM
rocky's Avatar
rocky
BaronVonAutomatc
Apr 3, 2014 08:05 PM
xjpilot
Nov 19, 2011 10:12 AM
BaronVonAutomatc
Jul 8, 2008 04:32 PM
SMS888
Jan 23, 2006 12:09 PM
jammergsxr
15
Apr 8, 2003 11:17 AM
