Welders
Old Mar 17, 2005 | 06:05 PM
ALSAIR's Avatar
ALSAIR
Welders
I use to be a welder in the Coast Gaurd (14 years ago) I would like to buy a welder. I used a Miller AC/DC Arc welder. Because of the A/C current was able to run a Tig set-up. Reverse Polarity. They are asking apretty pennie for a current set-up stick/tig. Why can't I just buy a AC/DC arc welder and add the Tig outfit at a later date?. I am thinking of a 225 or 250 Amp outfit for my Buisness. Suggestions or comments?
Thanks Al
Old Mar 17, 2005 | 06:16 PM
Sgt Wonderful's Avatar
Sgt Wonderful
Welder
Al, after being around the world with the Coast Guards you should know that you get what you pay for. A rube goldberg appapparatus is what you will have. If you want a tig welder get the best you can afford, and use it as it's intended.
"A Lifer"
Old Mar 18, 2005 | 09:46 AM
pbrunner's Avatar
pbrunner
I've had kinda the same thoughts for a while now. I have an AC stick welder but would like to get into a MIG/TIG so I could tackle some light work. I agree completely with Sgt. Get the best you can afford. Right now with one kid in college, another hopefully following --- I'm sure you get the idea. Does anyone know how to upgrade present equipment and would it be worth it?
MODs please feel free to move to garage/workshop if appropriate.
Old Mar 18, 2005 | 12:42 PM
yeha4x4's Avatar
yeha4x4
J.C wittney has a stitch welding attachment for I think 60.00 that attaches to your stick, arc or whatever you want to call it and reduces the amperage so you can weld sheet metal. I was going to buy it because Arc was all I knew but I had sold my Arc welder years ago. I needed something for the floors, cab corners, etc in my truck. I ended up with a Lincoln mig welder because I thought it would cover everything I would need it for. Good luck
Old Mar 18, 2005 | 04:34 PM
FLgargoyle's Avatar
FLgargoyle
There's a lot of welding info in the Garage and Workshop forum. Try a search there, it comes up every week.
Cruiseomatic
Apr 11, 2018 07:08 PM
ford2go
Apr 1, 2016 05:19 AM
wezol5484
22
Jan 29, 2009 10:44 AM
might_b_giant
Mar 12, 2002 11:07 PM
