Leaky Transfer Case
Old Mar 17, 2005 | 02:39 PM
jesus_man's Avatar
jesus_man
Leaky Transfer Case
Anyone run across this problem? On my '02 F-350 PSD 6spd my T-case was leaking at 50k miles. So with help, I drop it and replace the input seal. I thought all was good until a couple days later it's leaking again. I checked the breather hose and all is good there. I knew I had overfilled it slightly, so I pulled the fill plug and let it drain out. Once that was done, I replaced the plug, cleaned everything up again and ran it a couple more days. It seems to still be leaking so I cleaned one more time hoping it was just residual. It must have been, because I don't think it's leaking again. I don't think I overfilled it enough to cause it to leak, but that's the only thing I can think of. I will be crawling under it again tonight to check for any leaking. I am just curious if anyone esle had this trouble. Thanks!
J.D.
